[postgis-users] ST_Simplify
David William Bitner
bitner at gyttja.org
Fri Oct 22 10:45:31 PDT 2010
D-P simplification is not going to modify your start/end points. For a bit
of reference on the Douglas-Peuker simplification algorithm, see
http://en.wikipedia.org/wiki/Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm
On Fri, Oct 22, 2010 at 11:13 AM, Kevin Neufeld <kneufeld at refractions.net>wrote:
> I don't see any pdf posted, but that's ok, I get the idea.
> Isn't that interesting. To me, this looks like a robustness issue with
> ST_Simplify. Here, the starting point of the polygon's exterior ring is not
> on the corner.
> select
> st_astext(
> st_simplify(
> 'POLYGON ((
> 25 300,
> 275 300,
> 300 300,
> 300 275,
> 300 25,
> 300 0,
> 275 0,
> 25 0,
> 0 0,
> 0 25,
> 0 275,
> 0 300,
> 25 300
> ))', 1
> st_astext
> POLYGON((25 300,300 300,300 0,0 0,0 300,25 300))
> (1 row)
> I don't know why, but I too was expecting to see something like:
> POLYGON (( 0 300, 300 300, 300 0, 0 0, 0 300 ))
> You almost could use a function that shifts the ordinates in the exterior
> linear ring ... you could probably put something together fairly quickly in
> plpgsql (extract the exterior ring, use ST_GetPointN and ST_SetPointN, and
> rebuild the polygon).
> Once shifted, the starting ordinance would be on the corner and the (25
> 300) vertex would disappear with a rerun of ST_Simplify.
> JTS has the same issue.
> -- Kevin
> On 10/22/2010 2:33 AM, lplateandy wrote:
>> Hi Kevin,
>> Hopefully the attached (hopefully) PDF will help to show what i mean.
>> In producing the PDF i think i can see why the issue happens. It seems
>> that
>> the start and end point of the polygon geometery are the node i was hoping
>> might be removed during the simplify process.
>> Not sure if there is a way around this?
>> I do realise there are ways for a simple rectangle etc to fix this but the
>> example is mainly for illustration as the issue is a problem in more
>> complex
>> geometries.
>> Thanks
>> Andy
>> Kevin Neufeld wrote:
>>> Hi Andy,
>>> Can you post a small example?
>>> -- Kevin
>>> On 10/21/2010 10:02 AM, lplateandy wrote:
>>>> Hi,
>>>> I have, in the simplest example, a square polygon of 1 by 1 kilometer
>>>> size
>>>> with nodes every 25 meters.
>>>> I can use ST_Simplify (the_geom,5) to remove most of the points.
>>>> However, for some reason i end up with the four corner nodes and a fifth
>>>> node 25m clockwise from the top left corner.
>>>> In itself, this would be fine - 5 nodes is better than 160.
>>>> However, on some of the polygons, there are more complex boundaries
>>>> which
>>>> i
>>>> wish to smooth out using simplify. I would do this with ST_Simplify
>>>> (the_geom,26) example - going over the minimum 25 metres between any
>>>> nodes.
>>>> In the example of the square with 5 nodes, the problem i find then is
>>>> that
>>>> the top left node is removed and the one 25m clockwise remains. The
>>>> result
>>>> is that i no longer have a 1km square but sloping Western boundary
>>>> correctly
>>>> going 1km North South but incorrectly veering across 25m to the East.
>>>> Is there a way to remove the stray node so i am more likely to maintain
>>>> my
>>>> overall polygon shape. I did try st_simplifiypreservetopology but saw no
>>>> noticeable difference.
>>>> Hope that makes sense, any help much appreciated
>>>> Andy
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> http://old.nabble.com/file/p30027046/ST_simplify_issue.pdf
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101022/035c53c8/attachment.html>
