[postgis-users] Error when building from source on mac os x 10.6
Gis Mage gismage at gmail.com
Sun Oct 17 09:36:26 PDT 2010
Hi list!
I'm trying to build postgis from source on a snow leopard machine.
So I download the 1.5.3 source, configure like this:
*sudo ./configure --prefix=/opt/postgis
--with-pgconfig=/opt/pgsql/bin/pg_config --mandir=/opt/pgsql/man
--with-geosconfig=/opt/geos/bin/geos-config --with-projdir=/opt/proj*
and get a successful result:
 PostGIS is now configured for x86_64-apple-darwin10.7.0
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  C++ compiler:         g++ -g -O2
 -------------- Dependencies --------------
  GEOS config:          /opt/geos/bin/geos-config
  GEOS version:         3.3.0
  PostgreSQL config:    /opt/pgsql/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.1beta3
  PROJ4 version:        47
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.7.3
  PostGIS debug level:  0
 -------- Documentation Generation --------
  xsltproc:             /usr/bin/xsltproc
  xsl style sheets:
  dblatex:
  convert:
Then I do
*sudo make*
And get an error:
  "_lwline_free", referenced from:
      _askml2_inspected_buf in lwgeom_kml.o
      _askml2_inspected_size in lwgeom_kml.o
ld: symbol(s) not found for architecture i386
collect2: ld returned 1 exit status
lipo: can't open input file: /var/tmp//ccsIJfa2.out (No such file or
directory)
make[1]: *** [postgis-1.5.so] Error 1
make: *** [postgis] Error 2
So I've checked my /var/tmp dir and I really don't have *ccsIJfa2.out* file.
What am I doing wrong here?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101017/a0ca55cc/attachment.html>
