[postgis-users] Announcement: PostGIS Versioning System pgversion and QGIS Plugin
maning sambale emmanuel.sambale at gmail.com
Mon Oct 18 02:06:18 PDT 2010
I have created a new database for the pg_versioning.  I created pgvs
functions and got this error:
$ psql -d philippines -U **** -h **** -f createFunctions.sql
CREATE SCHEMA
CREATE TYPE
GRANT
psql:createFunctions.sql.1:32: NOTICE:  CREATE TABLE will create
implicit sequence "version_tables_version_table_id_seq" for serial
column "version_tables.version_table_id"
psql:createFunctions.sql.1:32: NOTICE:  CREATE TABLE / PRIMARY KEY
will create implicit index "version_table_pkey" for table
"version_tables"
CREATE TABLE
GRANT
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:createFunctions.sql.1:920: NOTICE:  function
versions.pgvsreverse(pg_catalog.varchar) does not exist, skipping
DROP FUNCTION
CREATE FUNCTION
The pgadminIII showed the added versions schema but I can't use it in qgis 1.7.
 On Mon, Nov 8, 2010 at 7:37 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Sweet! It's working on qgis 1.5 (ubuntu).  Will be watching this
> plugin.  Thanks!
> On Mon, Nov 8, 2010 at 7:13 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
>> I made an update to handle a non existing pgvs in the layers source db.
>> Please reinstall the plugin and try again.
>> Dr. Horst Düster
>> Stv. Amtschef / kantonaler GIS-Koordinator
>> Kanton Solothurn
>> Bau- und Justizdepartement
>> Amt für Geoinformation
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> Telefon ++41(0)32 627 25 32
>> Mobil ++41(0)79 511 54 12
>> Telefax ++41(0)32 627 22 14
>> mailto:horst.duester at bd.so.ch
>> http://www.agi.so.ch
>> -----Ursprüngliche Nachricht-----
>> Von: emmanuel.sambale at gmail.com [mailto:emmanuel.sambale at gmail.com]
>> Gesendet am: Montag, 8. November 2010 10:58
>> An: Düster Horst
>> Cc: postgis-users
>> Betreff: Re: Re: [postgis-users] Announcement: PostGIS Versioning System
>> On QGIS 1.4 (mac), I overridden the 1.5 warning and continued with the
>> install. Plugin manager didn't activate it.
>> On qgis 1.5.0 (ubuntu):
>> I had to install qtsql. Then the plugin was activated. Tested with
>> my test postgis data, I got this error when I used "Prepare layer for
>> versioning":
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>> File "/home/maning/.qgis/python/plugins/pgversion/pgVersion.py",
>> line 170, in doInit
>> if not self.tools.versionExists(mySchema, myTable):
>> File "/home/maning/.qgis/python/plugins/pgversion/pgVersionTools.py",
>> line 107, in versionExists
>> if len(result["SCHEMA"]) 0:
>> KeyError: 'SCHEMA'
>> Python version:
>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>> [GCC 4.4.3]
>> QGIS version:
>> 1.5.0-Tethys Tethys, exported
>> Python path: ['/usr/share/qgis/python', '/home/maning/.qgis/python',
>> '/home/maning/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
>> '/usr/local/lib/python2.6/dist-packages/Sphinx-0.6.5-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/docutils-0.6-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/Jinja2-2.4.1-py2.6.egg',
>> '/usr/local/lib/python2.6/dist-packages/Pygments-1.3.1-py2.6.egg',
>> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
>> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
>> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
>> '/usr/lib/python2.6/dist-packages/PIL',
>> '/usr/lib/python2.6/dist-packages/gst-0.10',
>> '/usr/lib/pymodules/python2.6',
>> '/usr/lib/python2.6/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.6/gtk-2.0',
>> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
>> '/usr/local/lib/python2.6/dist-packages',
>> u'/home/maning/.qgis//python/plugins',
>> '/usr/share/qgis/python/plugins/fTools/tools']
>> On Mon, Nov 8, 2010 at 5:21 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
>>> The plugin is marked as experimental and I had set the qgis minimum
>>> version
>>> to 1.5 due to I tested the plugin with 1.5. I changed the minimum version
>>> 1.4. Please try it and give me a responce whether it works.
>>> Regards
>>> Horst
>>> Dr. Horst Düster
>>> Kanton Solothurn
>>> SO!GIS Koordination
>>> Rötistrasse 4
>>> CH-4501 Solothurn
>>> Von: maning sambale [mailto:emmanuel.sambale at gmail.com]
>>> Gesendet am: Montag, 8. November 2010 10:10
>>> An: PostGIS Users Discussion
>>> Betreff: Re: [postgis-users] Announcement: PostGIS Versioning System
>>> Nice! What version of QGIS does it use. I added your repoe, but I
>>> can't find the plugin in my 1.4 version
>>> On Mon, Nov 8, 2010 at 4:08 PM, Javier de la Torre
>>> <jatorre at vizzuality.com> wrote:
>>>> Hi,
>>>> Thats great. Congratulations.
>>>> One question. If I understand correctly you are using the DB users for
>>>> the
>>>> versioning. How easy would be to use external users from, for example a
>>>> web
>>>> system? We normally do not use the users on PostgreSQL for the data
>>>> content.
>>>> Are you planning something on this direction?
>>>> Thanks.
>>>> Javier
>>>> www.vizzuality.com
>>>> On Nov 8, 2010, at 8:43 AM, Düster Horst wrote:
>>>> I just finished the first beta version of my newly released pgvs support
>>>> system. The idea of this system is to enable the editing of a single
>>>> PostGIS
>>>> layer concurrently by more than one user at the same time, similar to
>>>> source
>>>> code versioning systems like CVS or Subversion. You will find further
>>>> informations at:
>>>> http://www.kappasys.org/cms/index.php?id=23&L=5
>>>> You can download the PostGIS functions from:
>>>> http://www.kappasys.ch/pgtools/pgversion/createFunctions.sql
>>>> To get easy access to pgvs I additionally created the QGIS plugin
>>>> pgversion
>>>> which you can download from:
>>>> http://www.kappasys.org/qgis/plugins.xml
>>>> I know that not all features of a SVN like system are implemented yet.
>>>> But
>>>> I
>>>> would like to get your comments and ideas for further developements.
>>>> I hope that pgvs can make your life easier.
>>>> Regards
>>>> Horst
>>>> Dr. Horst Düster
>>>> Kanton Solothurn
>>>> SO!GIS Koordination
>>>> Rötistrasse 4
>>>> CH-4501 Solothurn
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
>> cheers,
>> maning
> cheers,
> maning
cheers,
maning
