[postgis-users] Announcement: PostGIS Versioning System pgversion and QGIS Plugin
maning sambale
emmanuel.sambale at gmail.com
Mon Oct 18 04:30:20 PDT 2010
>> The pgadminIII showed the added versions schema but I can't use it in qgis
>> 1.7.
> What do you mean with I can't use it in qgis 1.7? Please explain your
> problem more precise..
On QGIS 1.7, I can load the postgis layer but using the PG_version
Plugin: Database > PG Version > Prepare Layer for Versioning, I get
the following messages:
Fehlermeldung:' Driver not loaded.' Es kann keine Verbindung zur
Datenbank aufgebaut werden! Einige Funktionen des PlugIn doInit
funktionieren deshalb nicht!
Followed by:
Please upgrade the DB-functions from the file:
<Plugin-Directory>/pgversion/tools/updateFunctions.sql
If you have appropriate DB permissions you can update the DB directly
with click on DB-Update.
Driver not loaded Driver not loaded
I tried to manually update the updateFunctions.sql using psql but I
also get errors.
> Dr. Horst Düster
> Burchacker 6
> CH-4556 Aeschi
> Tel.: +41(0)62 961 03 74
> Mobil: +41(0)76 408 51 06
> E-Mail: horst.duester at kappasys.ch
> Skype: horstduester
> Web: http://www.kappasys.ch
> postgis-users mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
