[postgis-users] Error when building from source on mac os x 10.6
Gis Mage
gismage at gmail.com
Tue Oct 19 01:54:14 PDT 2010
Hi, again!
Thanks for your clues, but that didn't help.
I still have the same error.
I've exported and double checked theese variables.
I've rebuilt GEOS and PROJ with this flags.
My arch is:
uname -m
x86_64
I still get the same
"ld: symbol(s) not found for architecture i386"
error.
But it fires up in a different place now:
"_lwline_free", referenced from:
_LWGEOM_addpoint in lwgeom_functions_basic.o
_LWGEOM_envelope in lwgeom_functions_basic.o
_LWGEOM_line_from_mpoint in lwgeom_functions_basic.o
_BOX2DFLOAT4_to_LWGEOM in lwgeom_box2dfloat4.o
collect2: ld returned 1 exit status
lipo: can't open input file: /var/tmp//cccyfTRP.out (No such file or
directory)
make[1]: *** [postgis-2.0.so] Error 1
make: *** [all] Error 1
Is there still a library built for a different arch?
How to check that out?
2011/7/18 William Kyngesburye <woklist at kyngchaos.com>
> It looks like the different parts of postgis compilation (ie most of it
> comes from the Postgres make system) don't have the same information about
> what architectures to compile for.
> I always specify these before configuring postgis:
> export CFLAGS="-Os -arch i386 -arch x86_64"
> export PG_CPPFLAGS="-arch i386 -arch x86_64"
> export SHLIB_LINK="-arch i386 -arch x86_64"
> export LDFLAGS="-arch i386 -arch x86_64"
> Note that you need to know which architectures GEOS, PROJ and Postgres are
> compiled for. Use as many -arch flags in each of the above exports as is
> common to these. It may be i386 and x86_64, but it could also be only
> x86_64. If i386 is the only common arch, you should recompile to get at
> least x86_64.
> On Jul 17, 2011, at 11:42 AM, Gis Mage wrote:
> > Hi list!
> > I'm trying to build postgis from source on a snow leopard machine.
> > So I download the 1.5.3 source, configure like this:
> > sudo ./configure --prefix=/opt/postgis
> --with-pgconfig=/opt/pgsql/bin/pg_config --mandir=/opt/pgsql/man
> --with-geosconfig=/opt/geos/bin/geos-config --with-projdir=/opt/proj
> > and get a successful result:
> > PostGIS is now configured for x86_64-apple-darwin10.7.0
> > -------------- Compiler Info -------------
> > C compiler: gcc -g -O2
> > C++ compiler: g++ -g -O2
> > -------------- Dependencies --------------
> > GEOS config: /opt/geos/bin/geos-config
> > GEOS version: 3.3.0
> > PostgreSQL config: /opt/pgsql/bin/pg_config
> > PostgreSQL version: PostgreSQL 9.1beta3
> > PROJ4 version: 47
> > Libxml2 config: /usr/bin/xml2-config
> > Libxml2 version: 2.7.3
> > PostGIS debug level: 0
> > -------- Documentation Generation --------
> > xsltproc: /usr/bin/xsltproc
> > xsl style sheets:
> > dblatex:
> > convert:
> > Then I do
> > sudo make
> > And get an error:
> > _askml2_inspected_buf in lwgeom_kml.o
> > _askml2_inspected_size in lwgeom_kml.o
> > lipo: can't open input file: /var/tmp//ccsIJfa2.out (No such file or
> directory)
> > make[1]: *** [postgis-1.5.so] Error 1
> > make: *** [postgis] Error 2
> > So I've checked my /var/tmp dir and I really don't have ccsIJfa2.out
> file.
> > What am I doing wrong here?
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what does
> that remind me of? Ah, yes - life."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101019/3ecd1230/attachment.html>
