[postgis-users] shp2pgsql control over Z and M loading
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Sep 4 11:00:11 PDT 2010
Hi All's,
I wondering if anyone has thought about adding more control over the
loading of shapes with regard to Z and M values. I thinking about
something like adding options to the cli:
-z 0|1
-m 0|1
The behavior of these would be if they are not used then the same
behavior as now.
0 - would force that dimension off regardless of the shape data
1 - would force adding that dimension regardless of the shape data and
if the shape does not include that dimension it would default to 0.0
In addition, the_geom column would be created with the exact dimensions
used:
2 - x,y
3 - x,y,z
3 - x,y,m
4 - x,y,z,m
I assume this is possible.
Currently shp2pgsql always creates dims=4 for an ArcZ shapefile and it
seems like it should be create dims=3 since it is not using the M.
The motivation behind this is saving space on large data sets. I have a
33 GB shapefile data set in Arc, which grows to 36 GB for ArcZ. I
assume, maybe wrongly, that loading this will add the equivalent to 3 GB
more for the M dimension in the database. While this 10% waste is not
horrid, it will impact performance and data transfer time and this is
getting used in a web application.
Any thoughts on this would be appreciated.
Anyone interested in tackling this?
-Steve W
