[postgis-users] get segment of multiline between two points
Marco
marcpat at katamail.com
Tue Sep 14 08:33:36 PDT 2010
Thank you Andrea, it works!!
recapitulation for others user: if you have 2 point and you need one segment of the nearest layer
// select nearest layer (if multilinestring use ST_LineMerge(pt.the_geom) AS pt_geom)
SELECT pt.the_geom AS pt_geom, pt.gid AS pt_id
FROM line_layer pt
WHERE ST_DWithin(pt.the_geom, ST_GeomFromText('LINESTRING(1708654.405649647
4776470.575996869,1708894.1262744942 4776331.757517987)'), 10.0)
// SNAP points on the prev layer foreach point
SELECT ST_AsText(ST_Line_Interpolate_Point( pt_geom,
ST_Line_Locate_Point(pt_geom, ST_GeomFromText('POINT(1708654.405649647 4776470.575996869)'))
ST_Line_Locate_Point(pt_geom, ST_GeomFromText('POINT(1708894.1262744942 4776331.757517987)'))
// get segment from two prev points
SELECT ST_AsText(ST_Line_Substring(pt_geom,
ST_Line_Locate_Point(pt_geom,ST_GeomFromText('POINT(1708673.98843775 4776461.03369148)')),
ST_Line_Locate_Point(pt_geom,ST_GeomFromText('POINT(1708940.5269833 4776286.80931636)')))
Now my problem is: if the "select nearest layer" return 2 or more layers? It's same solution? Or I
need to intersect the resultant layer?
thanks again
Il 11/09/10 18.30, Andrea Peri ha scritto:
>>Thanks, I tried this function, but it returns all points and I need only that
>>are inside a segment between two points.
>>ie:
>>MULTILINESTRING((0 0,1 1,1 2,2 3,3 2,5 4))
>>POINT(1 1) POINT(3 2)
>>I want LINESTRING(1 1,1 2,2 3,3 2)
> Perhaps something like this is like for you.
> ST_Line_Substring(geometry_line,ST_Line_Locate_Point(geometry_line,geometryPoint_start),ST_Line_Locate_Point(geometry_line,geometryPoint_end))
> where
> geometryPoint_start = ST_GeomFromText('POINT(1,1)');
> geometryPoint_end = ST_GeomFromText('POINT(3,2)');
> Andrea Peri
> qwerty àèìòù
> postgis-users mailing list
