[postgis-users] srid for epsg 26915
David Fawcett
david.fawcett at gmail.com
Wed Sep 22 10:36:08 PDT 2010
OK, that makes sense.
So, it works well when installing additional SRS' , you won't mess up
your stock spatial_ref_sys.
The use case that I was going after was where a co-worker wanted to
know what srid to use when importing data from a shapefile. I was
attempting to use spatialreference.org as a reference to confirm what
the standard SRID for this SRS in PostGIS was. I guess that this
conflict comes up for SRS' that are part of the stock install.
Maybe there is a need for another line on the spatialreference.org
page for 'PostGIS SRID' ?
Of course, if one already has rights to add data to the db, you can
just run a simple (if you know the EPSG code):
SELECT *
FROM public.spatial_ref_sys
WHERE auth_name = 'EPSG'
AND auth_srid = 26915;
David.
On Wed, Sep 22, 2010 at 12:19 PM, David William Bitner
<bitner at gyttja.org> wrote:
> David,
> spatialreference.org uses a local SRID with a prepended '9' while
> maintaining an auth_srid to match EPSG so as not to step on the toes of the
> SRIDs that are already in the spatial_ref_sys table. While a bit ugly, this
> is the intended behavior. It uses the '9' because there are no EPSG codes
> that begin with a 9 so it is a clear namespace to not overwrite an EPSG code
> regardless of what local SRID identifier is given at spatialreference.org.
> Clear as mud?
> David
> On Wed, Sep 22, 2010 at 11:41 AM, David Fawcett <david.fawcett at gmail.com>
> wrote:
>> A minor issue here, but I am looking for some clarification.
>> I am seeking the correct PostGIS srid for UTM Z15N NAD83.
>> If I query spatialreference.org,
>> (http://spatialreference.org/ref/epsg/26915/postgis/) I get:
>> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text,
>> srtext) values ( 926915, 'epsg', 26915, '+proj=utm +zone=15
>> +ellps=GRS80 +datum=NAD83 +units=m +no_defs ', 'PROJCS["NAD83 / UTM
>> zone 15N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
>> 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4269"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-93],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],AUTHORITY["EPSG","26915"],AXIS["Easting",EAST],AXIS["Northing",NORTH]]');
>> From a fairly recent of PostGIS,
>> SELECT srid, auth_name, auth_srid
>> WHERE auth_srid = 26915
>> I get: 26915 | EPSG | 26915
>> I am assuming that the definition at spatial ref.org is wrong?
>> David.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
