[postgis-users] Efficient SQL for point in field of shapes?
John Poole
jlpoole56 at gmail.com
Wed Sep 22 20:38:28 PDT 2010
On Tue, Sep 7, 2010 at 1:21 PM, Sean <seanasy at gmail.com> wrote:
> On Sep 3, 12:55 pm, John Poole <jlpool... at gmail.com> wrote:
>> I have a table of assessor parcels (polygons) and I want to take a
>> given point (actually will be taking samplings from a geocache
>> tracker, so I'll be doing hundreds, possibly thousands of such
>> queries) and determine which, if any, of the shapes contain the point.
>> The goal is to determine which parcel a tracked person is within and
>> at what times.
>> I'm new to spatial database, and suspect performing a relate or
>> ST_contains against the 40,000 shapes would be horribly inefficient,
>> especially if I have thousands of points. Should I be reading up on
>> indexes, or is there an elegant solution to this problem.
>> I tried searching the archive of this list for "point in field of
>> shapes" but results were too generic.
>> John L. Poole
> That shouldn't be very taxing. A bounding box check in the where
> clause should help speed things up. e.g.
> select p.id
> from parcels p left join geocache g on st_contains(p.geom, g.geom)
> where p.geom && g.geom
> You'll only really know how efficient it is when you try it with real
> data. Of course, make sure you have a spatial index on the polygons.
> Sean
> postgis-users mailing list
You're right, it was not taxing, my worry was misplaced and the
response times are within acceptable ranges.
Thank you
John L. Poole
P.O. Box 6566
Napa, CA 94581-6566
707-812-1323
