[postgis-users] problem to obtain intersection: TopologyException
Birgit Laggner
birgit.laggner at vti.bund.de
Mon Sep 27 05:59:06 PDT 2010
Hi Salas,
did you check if your geometries are all valid (with function
st_isvalid(geometry))?
Regards,
Birgit.
On 24.09.2010 16:33, salas wrote:
> Hi,
> I have a table 'municipio' with a geometric column (the_geom). I want
> to get a view with the resultant of the interception between the
> the_geom column and a polygon.
> The query:
> SELECT ST_Dump(ST_Intersection(the_geom,
> GeomFromText('MULTIPOLYGON(((177056.442675 283157.030268,
> 283157.030268 192559.320783, 192559.320783 293446.551137,
> 177056.442675 293446.551137, 177056.442675 283157.030268)))',2085)))
> FROM municipio
> WHERE the_geom IS NOT NULL
> AND ST_Intersects(the_geom,
> 177056.442675 293446.551137, 177056.442675 283157.030268)))',2085)) = TRUE
> return an error:
> NOTICE: TopologyException: found non-noded intersection between
> 178970 311240, 178977 311221 and 178976 311224, 178971 311238 178972
> 311234
> ERROR: GEOS Intersection() threw an error!
> ********** Error **********
> SQL state: XX000
> What's the problem ????
> The WHERE statemente ((the_geom, GeomFromText( ...) ) ensure the
> intersection
> Best regards, Salas
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100927/24f1537c/attachment.html>
