[postgis-users] Help?: Constructing a geometry collection
John Poole
jlpoole56 at gmail.com
Mon Sep 27 16:07:19 PDT 2010
That worked; sublimely simple.
Thank you!
On Mon, Sep 27, 2010 at 3:43 PM, Richard Greenwood
<richard.greenwood at gmail.com> wrote:
> I think this should do the trick:
> SELECT EXTENT(the_geom)
> FROM parcels_public
> WHERE gid > 27611 AND gid < 28000;
> Rich
> On Mon, Sep 27, 2010 at 9:05 AM, John Poole <jlpoole56 at gmail.com> wrote:
>> I've been grappling with the following concept and reviewing the
>> PostGIS 1.5.1 Manual and cannot seem to come up with a working
>> solution to achieve this simple goal:
>> GOAL: I want to collect various polygons and then determine the
>> bounding box or extent of the collection in order to display an
>> appropriately zoomed image on MapServer
>> Here's the SQL I'm starting with:
>> select the_geom from parcels_public where gid > 27611 and gid < 28000
>> returns
>> 388 rows of geometries.
>> How do I create a geometry collection from a set of rows? I've been
>> looking at ST_Collect and trying:
>> * * * warning below is bad code * * *
>> Select ST_Collect((select the_geom from parcels_public where gid >
>> 27611 and gid < 28000)) as myCollectionObject
>> which produces:
>> ERROR: more than one row returned by a subquery used as an expression
>> ********** Error **********
>> SQL state: 21000
>> Referencing the thread in the documentation,
>> http://postgis.refractions.net/pipermail/postgis-users/2008-June/020331.html
>> I tried this
>> SELECT ST_Multi(ST_Collect(f.the_geom)) as singlegeom
>> FROM (
>> SELECT (
>> select the_geom
>> from parcels_public
>> where gid > 27611 and gid < 27640
>> ) As f
>> which produces:
>> ERROR: column f.the_geom does not exist
>> LINE 1: SELECT ST_Multi(ST_Collect(f.the_geom)) as singlegeom
>> SQL state: 42703
>> Character: 28
>> I know this can be done, but I seemed to be missing something very
>> basic both in creating subqueries and in the documentation and I'm
>> confusing structure, e.g. rows returned vs. a geometry collection.
>> Maybe my problem is that I do not know how to construct a geometry
>> collection from a given set of rows?
>> The end goal is to have the coordinates of the collection so I can use
>> them as an extent to send to MapServer to create an image that is
>> zoomed into the minimum size that displays all members of the
>> collection. I anticipate using ST_Extent(myCollectionObject) once I'm
>> able to create the collection object.
>> John L. Poole
>> P.O. Box 6566
>> Napa, CA 94581-6566
>> 707-812-1323
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Richard Greenwood
> www.greenwoodmap.com
John L. Poole
P.O. Box 6566
Napa, CA 94581-6566
707-812-1323
