[postgis-users] shape to postgis inporter fails or crashes
Paul Ramsey pramsey at opengeo.org
Thu Sep 30 11:19:40 PDT 2010
There was a crasher in the GUI associated with encoding that was
fixed, so when the 1.5.2 builds are out, give them a try, hopefully it
should be gone. Can you give me a URL for the afghanistan files to
download from?
On Thu, Sep 30, 2010 at 11:12 AM, Clay, Bruce <bclay at ball.com> wrote:
> Paul:
>  Thanks for the reply
> I was using the gui version on windows.  And yes it actually crashed.  I was using it on a machine where I cannot get to my email so I can't run the same test that causes a crash.
> The crash may be from a sequence of events rather than a single event.  When I try to load another file that has caused crashes before I get the following error:
> Failed record number #35
> Failed SQL begins: "INSERT INTO "public"."Elevation_Point" ("objectid","nam","acc","ela","mcc","na2","na3","na4","tse","zv2","cdv","ocx","ocy","gblink","na6","akt","otn","modificati","fldbid","scale","originatin","pmid","ltt_curren","ltt_featur","ltt_versio","ltt_status","l"
> Failed in pgui_exec(): ERROR:  current transaction is aborted, commands ignored until end of transaction block
> It processed several lines before starting to report errors but it did not crash when I did it from this location although it did at the place I have been working.
> One file that gives the encoding error is afghanistan_natural.shp from the OSM shapefile dataset as does afghanistan_poi.shp and afghanistan_water.shp
> Bruce
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Thursday, September 30, 2010 1:22 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] shape to postgis inporter fails or crashes
> Just use the -w switch to specify WINDOWS-1252 as your encoding.
> Should work fine from there.
> P.
> BTW, it shouldn't crash, it should just stop and show the error. Is
> that what it is doing, or do you get honest-to-god coredumps?
> On Thu, Sep 30, 2010 at 10:17 AM, Clay, Bruce <bclay at ball.com> wrote:
>> I am trying to load OpenStreetMap and GDAM data from the shapefiles that
>> were posted on the network.  Some of the work file but those with special
>> characters often fail or in came cases the application crashes.
>> The error message  get is -  Unable to convert field value "<some osm name>"
>> to UTF-8: iconv reports "Illegal byte sequence"
>> DBF file character encoding is set to WINDOWS-1252 which if I am reading
>> correctly should support Unicode characters.
>> Based on comments posted on the net I also tried setting encoding to
>> "Latin1"
>> Any thoughts on how to correct this problem would be greatly appreciated.
>> I am using PostgreSql version 8.8 and PostGis 1.5.1
>> Bruce
>> This message and any enclosures are intended only for the addressee.  Please
>> notify the sender by email if you are not the intended recipient.  If you
>> are
>> not the intended recipient, you may not use, copy, disclose, or distribute
>> this
>> message or its contents or enclosures to any other person and any such
>> actions
>> may be unlawful.  Ball reserves the right to monitor and review all messages
>> and enclosures sent to or from this email address.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
