[postgis-users] Postgis Installation Error
vikashvikky vikashtalanki at gmail.com
Wed Apr 6 13:02:22 PDT 2011
Hi frnds,
      I am using fedora machine. I want to install postgis on my system. So
this is what I have done
1. Installed Postgresql and supporting packages using YUM.
2. Created directory /sources to put all the necessary packages for postgis.
3. successfully installed geos,libxml & proj using ./config,make,make
install.
4. successfull in make & make install of postgis. But when I give "make
check" I am getting the following error(I have alreasy started the postgres
server):
[root at localhost sources]# cd postgis/
[root at localhost postgis]# ls
postgis-1.5.0SVN  postgis-1.5.0SVN.tar.gz
[root at localhost postgis]# cd postgis-1.5.0SVN
[root at localhost postgis-1.5.0SVN]# make check
make -C liblwgeom
make[1]: Entering directory `/sources/postgis/postgis-1.5.0SVN/liblwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/liblwgeom'
make -C postgis
make[1]: Entering directory `/sources/postgis/postgis-1.5.0SVN/postgis'
Makefile.pgxs:17: warning: overriding recipe for target `install'
/usr/lib/pgsql/pgxs/src/makefiles/pgxs.mk:92: warning: ignoring old recipe
Makefile.pgxs:63: warning: overriding recipe for target `installdirs'
/usr/lib/pgsql/pgxs/src/makefiles/pgxs.mk:140: warning: ignoring old recipe
Makefile.pgxs:82: warning: overriding recipe for target `uninstall'
/usr/lib/pgsql/pgxs/src/makefiles/pgxs.mk:164: warning: ignoring old recipe
make[1]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/postgis'
make -C liblwgeom/cunit check
`/sources/postgis/postgis-1.5.0SVN/liblwgeom/cunit'
WARNING:
configure was unable to find CUnit which is required for unit testing.
In order to enable unit testing, you must install CUnit and then re-run
configure.
make -C regress check
make[1]: Entering directory `/sources/postgis/postgis-1.5.0SVN/regress'
make -C ../postgis REGRESS=1
DESTDIR=/sources/postgis/postgis-1.5.0SVN/regress/00-regress-install install
make[2]: Entering directory `/sources/postgis/postgis-1.5.0SVN/postgis'
/bin/sh /usr/lib/pgsql/pgxs/src/makefiles/../../config/mkinstalldirs
'/sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/lib'
/bin/sh /usr/lib/pgsql/pgxs/src/makefiles/../../config/install-sh -c -m 755
postgis-1.5.so
'/sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/lib/postgis-1.5.so'
/bin/sh /usr/lib/pgsql/pgxs/src/makefiles/../../config/install-sh -c -m 644
./../spatial_ref_sys.sql
'/sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/share/contrib/postgis-1.5'
postgis.sql
uninstall_postgis.sql
postgis_upgrade_15_minor.sql
postgis_upgrade_14_to_15.sql
postgis_upgrade_13_to_15.sql
postgis-1.5.so
make[2]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/postgis'
make -C ../loader REGRESS=1
make[2]: Entering directory `/sources/postgis/postgis-1.5.0SVN/loader'
Makefile:108: warning: overriding recipe for target `clean'
/usr/lib/pgsql/pgxs/src/makefiles/pgxs.mk:211: warning: ignoring old recipe
for target `clean'
pgsql2shp /sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/bin
shp2pgsql /sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/bin
make[2]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/loader'
sed
's,$libdir,/sources/postgis/postgis-1.5.0SVN/regress/00-regress-install/lib,g'
../postgis/postgis.sql > postgis.sql
psql: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
Creating spatial db postgis_reg
createdb: could not connect to database postgres: could not connect to
createlang: could not connect to database postgis_reg: could not connect to
dropdb: could not connect to database postgres: could not connect to server:
 Something went wrong (no postgis installed in postgis_reg).
 For details, check /tmp/pgis_reg_5204/regress_log
make[1]: *** [check] Error 1
make[1]: Leaving directory `/sources/postgis/postgis-1.5.0SVN/regress'
make: *** [check] Error 2
6. Even with the error, i continued to create template_postgis db from
postgresql shell:
 On giving the command: psql template_postgis -U postgres
postgis/postgis.sql I am getting the folowing error:
psql:postgis/postgis.sql:6859: NOTICE:  type "geography" is not yet defined
DETAIL:  Creating a shell type definition.
CREATE FUNCTION
psql:postgis/postgis.sql:6865: NOTICE:  argument type geography is only a
shell
CREATE FUNCTION
CREATE FUNCTION
CREATE TYPE
psql:postgis/postgis.sql:6893: NOTICE:  type "gidx" is not yet defined
CREATE FUNCTION
psql:postgis/postgis.sql:6899: NOTICE:  argument type gidx is only a shell
CREATE FUNCTION
psql:postgis/postgis.sql:7744: NOTICE:  aggregate geomunion(geometry) does
not exist, skipping
DROP AGGREGATE
psql:postgis/postgis.sql:7745: NOTICE:  aggregate st_geomunion(geometry)
does not exist, skipping
DROP AGGREGATE
psql:postgis/postgis.sql:7746: NOTICE:  aggregate accum_old(geometry) does
not exist, skipping
DROP AGGREGATE
psql:postgis/postgis.sql:7747: NOTICE:  aggregate st_accum_old(geometry)
DROP AGGREGATE
psql:postgis/postgis.sql:7750: NOTICE:  function box2d_overleft(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7751: NOTICE:  function
box2d_overright(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7752: NOTICE:  function box2d_left(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7753: NOTICE:  function box2d_right(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7754: NOTICE:  function box2d_contain(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7755: NOTICE:  function
box2d_contained(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7756: NOTICE:  function box2d_overlap(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7757: NOTICE:  function box2d_same(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7758: NOTICE:  function
box2d_intersects(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7759: NOTICE:  function
st_box2d_overleft(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7760: NOTICE:  function
st_box2d_overright(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7761: NOTICE:  function st_box2d_left(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7762: NOTICE:  function st_box2d_right(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7763: NOTICE:  function
st_box2d_contain(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7764: NOTICE:  function
st_box2d_contained(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7765: NOTICE:  function
st_box2d_overlap(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7766: NOTICE:  function st_box2d_same(box2d,box2d)
DROP FUNCTION
psql:postgis/postgis.sql:7767: NOTICE:  function
st_box2d_intersects(box2d,box2d) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7768: NOTICE:  function st_addbbox(geometry) does
not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7769: NOTICE:  function st_dropbbox(geometry) does
not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7770: NOTICE:  function st_hasbbox(geometry) does
not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7771: NOTICE:  function cache_bbox() does not
exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7772: NOTICE:  function st_cache_bbox() does not
exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7773: NOTICE:  function
transform_geometry(geometry,text,text,pg_catalog.int4) does not exist,
skipping
DROP FUNCTION
psql:postgis/postgis.sql:7774: NOTICE:  function
collector(geometry,geometry) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7775: NOTICE:  function
st_collector(geometry,geometry) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7776: NOTICE:  function
geom_accum(geometry[],geometry) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7777: NOTICE:  function
st_geom_accum(geometry[],geometry) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7778: NOTICE:  function collect_garray(geometry[])
DROP FUNCTION
psql:postgis/postgis.sql:7779: NOTICE:  function
st_collect_garray(geometry[]) does not exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7780: NOTICE:  function geosnoop(geometry) does not
exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7781: NOTICE:  function jtsnoop(geometry) does not
exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7782: NOTICE:  function st_noop(geometry) does not
exist, skipping
DROP FUNCTION
psql:postgis/postgis.sql:7783: NOTICE:  function
st_max_distance(geometry,geometry) does not exist, skipping
DROP FUNCTION
-bash-4.1$
Any solution for this is of great help. thanx in advance
View this message in context: http://old.nabble.com/Postgis-Installation-Error-tp31336778p31336778.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
