[postgis-users] "Linux" geocoder script ?
Sylvain Racine
syracine at sympatico.ca
Mon Apr 11 18:52:52 PDT 2011
Hello,
This is not a shp2pgsql bug. You get this error when you try to insert
string data in PostgreSQL from another encoding that the one of your
database Ex: Your data is formatted in Latin1 (ISO-8859-1) and you
insert them in a UTF-8 database. To fix the error message, you need to
convert your data.
PostgreSQL have a internal converter. shp2pgsql have it too. Try
shp2pgsql -W <encoding> where <encoding> is the format of you DBase file
.dbf. This is called the "client encoding" in PostgreSQL. See list of
valid encoding type:
http://www.postgresql.org/docs/9.0/static/multibyte.html
Don't mix it with the database encoding. It is the one you us to create
your databse. There is also a default database charset, depending of
your OS. It is the one you use to create template1 database in init-db.
Mine is "UTF8" on Ubuntu.
Hope that this information will help you
Regards
Sylvain Racine
On 2011-04-11 21:22, Don wrote:
> I have got the tiger2010 geodecoder to work on my Opensuse system.
> geocoder=#
> geocoder=# SELECT g.rating,
> geocoder-# ST_X(geomout) As lon,
> geocoder-# ST_Y(geomout) As lat, (addy).*
> geocoder-# FROM geocode('1731 New Hampshire Avenue Northwest,
> Washington, DC 20010') As g;
> rating | lon | lat | address |
> predirabbrev | streetname | streettypeabbrev | postdirabbrev |
> internal | location | stateabbrev | zip | parsed
> 0 | -77.0399013800607 | 38.9134181361424 | 1731
> | | New Hampshire | Ave | NW
> | | Washington | DC | 20009 | t
> (1 row)
> There are a few glitches. I noticed that I am getting this message
> sometimes.
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> ERROR: invalid byte sequence for encoding "UTF8": 0xed6f20
> HINT: This error can also happen if the byte sequence does not match
> the encoding expected by the server, which is controlled by
> "client_encoding".
> ERROR: current transaction is aborted, commands ignored until end of
> transaction block
> transaction block
> transaction block
> I researched this some and it appears to be a shp2pgsql bug.
> But I am using postgis-utils-2.0.0SVN-1.2.x86_64
> postgis-2.0.0SVN-1.2.x86_64 where this has supposedly been fixed. Or
> could the census data be corrupted?
> So I have "lost" some of the data due to this error.
> I had problems with psql generating ctrl-m instead of \n which would
> really mess up the script when it ran.
> So after I generated my load tiger script I ran this command
> tr "\r" "\n" < load_tiger > load_tiger2
> postgis-users mailing list
