[postgis-users] Determine if point is north of another point
GOO Creations
goocreations at gmail.com
Sun Apr 17 02:07:30 PDT 2011
Thank you, that worked.
Peter
On 2011/04/16 08:12 PM, Stephen Woodbridge wrote:
> On 4/16/2011 12:14 PM, GOO Creations wrote:
>> Hi all
>> I'm looking for a way to determine if a point P1 is (more or less) north
>> of point P2. Is there any easy way of doing this.
>> I've thought of using the latitudes of the points, but I having problems
>> constructing the query (especially since the latitudes can be positive
>> and negative)
>> Any help will be appreciated
> select * from points where st_y(the_geom) > <some latitude> order by
> st_y(the_geom);
> more north is always greater latitude.
> -Steve
> postgis-users mailing list
