[postgis-users] Postgis 2.0 and geoserver 2.1 rc4
Maria Arias de Reyna
marias at emergya.es
Mon Apr 18 00:18:09 PDT 2011
El Monday 18 April 2011, 龙龙 escribió:
> Hi, I am getting the following error when trying to add a layer from a
> postgis 2.0 database: java.lang.RuntimeException: java.io.IOException:
> Error occured calculating bounds at
> org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.ja
> va:476) at
> org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java
> :178) at
> org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSourc
> e.java:369) at
> e.java:341) at
> org.geotools.data.SimpleFeatureSourceBridge.getBounds(SimpleFeatureSourceB
> ridge.java:49) at
> org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatur
> eSource.java:529) at
> org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:4
> 63) at
> org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResour
> ceConfig.java:115) at
> org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubm
> itLink.java:68) at
> org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitB
> ehavior.java:143) at
> org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:17
> 7) at
> org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefau
> ltAjaxBehavior.java:300) at
> org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.
> processEvents(BehaviorRequestTarget.java:119) at
> org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(Abst
> ractRequestCycleProcessor.java:92) at
> org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1
> 250) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at
> org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at
> org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at
> org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
> at
> org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:16
> 0) at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at
> org.springframework.web.servlet.mvc.ServletWrappingController.handleReques
> tInternal(ServletWrappingController.java:158) at
> org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abstr
> actController.java:153) at
> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(
> SimpleControllerHandlerAdapter.java:48) at
> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherSer
> vlet.java:875) at
> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServ
> let.java:809) at ....
> But this problem doesn't exist when I use postgis 1.5. So, is this a
> postgis problem or a geoserver problem. How shall I deal with it?
The data from the table is the same?
I had this error once when the geometry column wasn't correctly defined. Are
you sure the table is defined on the geometry_columns table?
Can you look inside geoserver to see which is the exact sql sentence that is
used there?
María Arias de Reyna Domínguez
Área de Operaciones
Emergya Consultoría
Tfno: +34 954 51 75 77 / +34 607 43 74 27
Fax: +34 954 51 64 73
www.emergya.es
