[postgis-users] Calculate z value based on attribute field
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 21 14:05:52 PDT 2011
Right, that make perfect sense. You created a geometry column of tile
MULTIPOLYGON and you are trying to add a POINT to it!
What is your original geometry type?
if it is a POINT then do
select
addgeometrycolumn('public','allhousefinal','the_geom3d',4326,'POINT',3);
if it is a MULTIPOLYGON then you need to change the way you are adding
the z to it and do something like:
update allhousefinal set the_geom3d =
st_translate(st_force_3d(the_geom), 0, 0, result_hig*3);
I have not tested this so you might have to play with it a little.
-Steve W
On 4/21/2011 11:32 AM, Gis Mage wrote:
> Hello again!
> Doing as proposed I get an error.
> wizbase=# select
> addgeometrycolumn('public','allhousefinal','the_geom3d',4326,'MULTIPOLYGON',3);
> addgeometrycolumn
> public.allhousefinal.the_geom3d SRID:4326 TYPE:MULTIPOLYGON DIMS:3
> (1 row)
> wizbase=# update allhousefinal set the_geom3d = st_union(the_geom,
> st_setsrid(st_makepoint(st_x(st_pointonsurface(the_geom)),st_y(st_pointonsurface(the_geom)),
> result_hig*3),st_srid(the_geom)));
> ERROR: new row for relation "allhousefinal" violates check constraint
> "enforce_geotype_the_geom3d"
> As you can see the geometry type is MULTIPOLYGON, so I think the problem
> is somewhere around st_makepoint.
> Can you please help me out?
> Nikolai
> Re: [postgis-users] Calculate z value based on attribute
> field
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>>
> Message-ID: <20110419175447.GG13611 at keybit.net
> <mailto:20110419175447.GG13611 at keybit.net>>
> Content-Type: text/plain; charset=us-ascii
> On Tue, Apr 19, 2011 at 01:45:48PM -0400, Stephen Woodbridge wrote:
> > On 4/19/2011 8:52 AM, Gis Mage wrote:
> > >Hello list!
> > >I've got a table in PostGIS with the_geom field with 2 dimensions.
> > >I wonder how can I add a z dimension and fill it up with values from
> > >attribute field elev (its type is integer) ?
> > One way would be to add a new geometry column and then populate it,
> > maybe something like (untested):
> > select addgeomtrycolumn('myschema', 'mytable', 'geom3d', 4326,
> 'POINT', 3);
> > update mytable set geom3d=setsrid(makepoint(st_x(
> the_geom),
> > st_y(the_geom), z_column::double percision), 4326);
> A geometry type agnostic way would be to union whatever you have
> with a 3d point known to be contained in it. GEOS would then use
> the only Z value to fill up an elevation grid used to elevate
> the resulting geometry:
> -- untested query
> update mytable set geom3d = st_union(the_geom,
> z_column), st_srid(the_geom)));
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-users mailing list
