[postgis-users] Postgis -> Mapserver white background
Graham Walker
gwalker84 at gmail.com
Wed Apr 27 01:13:12 PDT 2011
Thanks for the response Ben.
I am accessing it through:
http://127.0.0.1/cgi-bin/mapserv.exe?map=C:\ms4w\Apache\htdocs\test.map&layer=all&mode=map
It just returns a blank png file.Currently, the table itself only
contains one polygon, set with an SRID of 27700. The table has three
columns in total, GID, name and the_geom. It was imported to
postgreSQL using the shapefile and DBF loader. I can connect and get
the polygon to display through QGIS without any issues through "adding
a PostGIS layer" function.
postgis.sql and spatial_ref_sys.sql have both been run.
Is there anything else that might help? What do you require for me to
attach the table definition?
Thanks,
On 27 April 2011 08:45, Ben Madin <lists at remoteinformation.com.au> wrote:
> Graham,
> It looks OK to me. Although the brevity is good, it might help if you could also attach the table definition - is it just producing a blank png image? is it in the same projection etc...? How are you accessing it (ie through WMS, mapscript or standard mapserver output).
> I've also copied this back to MapServer list...
> cheers
> Ben
> On 27/04/2011, at 3:26 PM, Graham Walker wrote:
>> Hi all, fairly new to all this. I was wondering if you could help me
>> with the following issue. I can't seem to display my postgis table in
>> mapserver. I can display shapefiles and html templates fine, but when
>> I try to connect to my postgis table I simply get a white background
>> (or whatever colour I set it as).
>> I have managed to display postgis tables before in mapserver, but I am
>> having no luck in this one and cannot see any differences. Both the
>> shapefile and postgis table can display in qgis. My map file is listed
>> below. I have intentionally tried to simplify this down to the basics
>> so it has no projection details, etc at present. Any help would be
>> greatly appreciated. Thanks
>> MAP
>> NAME "test"
>> IMAGETYPE PNG
>> SIZE 400 500
>> STATUS ON
>> EXTENT 200949 883531 347001 979508
>> SHAPEPATH "C:\ms4w\Apache\htdocs\test"
>> UNITS METERS
>> END
>> WEB
>> IMAGEPATH "c:\ms4w\tmp\ms_tmp\"
>> IMAGEURL "/ms_tmp/"
>> END
>> #Region Polygons
>> LAYER
>> NAME "North"
>> CONNECTIONTYPE postgis
>> CONNECTION "user=postgres password=1
>> dbname=test host=localhost port=5432"
>> DATA "the_geom from North"
>> TYPE POLYGON
>> STATUS DEFAULT
>> CLASS
>> STYLE
>> COLOR 1 1 1
>> OUTLINECOLOR 1 1 1
>> END
>> END
>> END
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
