[postgis-users] adding csv tables
John Callahan
john.callahan at udel.edu
Wed Aug 10 13:02:16 PDT 2011
Of course! Putting the csv file on the same machine as the database would
help. Single quotes with forward slashes work fine. Sorry for wasting
your time...
- John
On Wed, Aug 10, 2011 at 3:33 PM, Charles Galpin <cgalpin at lhsw.com> wrote:
> I use single forward slashes just fine, but just in case, this has to be
> run on the same machine as the server afaik.
> charles
> On Aug 10, 2011, at 3:28 PM, John Callahan wrote:
> Sorry if this is more of a postgres question than postgis...
> I'm trying to bring in a CSV table into my postgis database. I'm using the
> COPY command but kepe getting the error "No such file or directory." I'm on
> Windows and my guess is the error is caused by incorrect syntax. The online
> docs mentions that Windows users might need to use the E'' string syntax.
> What is that and how is it used? I can't find any good examples. Is the
> following correct? Thanks.
> COPY mypgtable FROM 'C:\\data\\projectname\\locations.csv' CSV HEADER;
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey
> University of Delaware
> URL: http://www.dgs.udel.edu
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110810/bba12517/attachment.html>
