[postgis-users] st_HausdorffDistance
Nicolas Ribot
nicolas.ribot at gmail.com
Sun Aug 14 09:07:01 PDT 2011
> Hi
> I’m looking at st_HausdorffDistance.
> When I run the example found at
> http://postgis.refractions.net/docs/ST_HausdorffDistance.html
> SELECT st_HausdorffDistance( 'LINESTRING (0 0, 2 0)'::geometry, 'MULTIPOINT
> (0 1, 1 0, 2 1)'::geometry);
> I get the error “No function matches the given name and argument types. You
> might need to add explicit type casts”.
> Help will be appreciated.
> Bob
Hi Bob
What version of Postgis do you run (select postgis_full_version()) ?
st_HausdorffDistance is pretty recent: Availability: 1.5.0 - requires
GEOS >= 3.2.0.
Nicolas
