[postgis-users] ERROR: Unknown geometry type: 0 - Unknown
Sandro Santilli
strk at keybit.net
Wed Aug 17 14:14:55 PDT 2011
On Wed, Aug 17, 2011 at 04:03:43PM +0200, Andreas Forø Tollefsen wrote:
> Great. Thank you Sandro.
> That worked. I managed to install the 6874 SVN and are now able to query the
> geometry columns as well.
> I then tried to backup the database, but got an error on two of my tables
> regarding the function postgis_typmod_out.
> Both of the tables in question have been read from a CSV file into a table
> in the database. I dropped these tables and now i can backup the database.
> The complete error: "ERROR: could not find the function "postgis_typmod_out"
> in file "/usr/lib/postgresql/8.4/lib/postgis-2.0.so"
Don't worry about those, must be new functions defined in newer postgis
that weren't available in older one.
> By the way. Can i actually have two databases built from two different SVN
> revisions at the same time? Is that possible at all?
Not easily.
You'd have to install libraries in two different directories and reference
the correct one from each postgis.sql file.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
