[postgis-users] connecting to postgis form mapserver
David Fawcett david.fawcett at gmail.com
Wed Aug 17 14:15:29 PDT 2011
You will either need to add the layer name explicitly in the request URL, or set the layer status to DEFAULT.
David
On Aug 17, 2011, at 3:09 PM, Vishal Mehta <vishal.mehta at sei-us.org> wrote:
> Hi all,
> I am testing out mapserver-postgis and a simple test is returning an empty map. Here is my  map file
> MAP
>   IMAGETYPE   PNG
>   EXTENT 77.5 12.95 77.7 13.01
>   SIZE        550 450
>   IMAGECOLOR  255 255 255
>   SHAPEPATH   "../data"
>     # Start of LAYER DEFINITIONS-------------------------------
>   LAYER
>     CONNECTIONTYPE POSTGIS
>                 NAME "wards"
>     # Connect to a remote spatial database
>                 CONNECTION "host=localhost port=5432 dbname=empty user=postgres password=xxx"
>                   # Get the lines from the 'geom' column of the 'wards' table
>                   DATA 'geom from "myschema.wards198" using srid=4326 using unique gid'
>                   STATUS ON
>                   TYPE POLYGON
>     CLASS
>       NAME "wards"
>       STYLE
>         OUTLINECOLOR 255 0 0
>       END
>     END
>   END
>   # End of LAYER DEFINITIONS -------------------------------
> END
> And the html that calls it
> <html>
> <head>
> <title>my postgis map</title>
> </head>
> <body bgcolor=white>
> <center>
> <br>
> <table width=570>
> <tr>
>    <td>
>      <br>
>      <img width=550 height=450
>      src=/cgi-bin/mapserv.exe?map=C:\OSGeo4W/apps/mapserver-tutorial/mytests/example.map&mode=map
>      border=1>
>    </td>
> </tr>
> </table>
> <br>
> </body>
> </html>
> Other info:
> Platform:
> -          Windows 7, postgresql9 , postgis 2.0
> -          I installed Mapserver separately through the OSGEO4 installer.
> -          I can connect to the same database through php
> -          I can create simple mapserver apps using shapefiles etc alright (e.g. same map file above, calling a shapefile, works fine)
> -          Mapserv.exe –v shows that it was installed with postgis support.
> -          Also can Mapserver handle postgis Mulipolygon geometry ok?
> I did check most of the points here which seemed ok ( i did not check those in this list that I don’t really know how to in Windows ).
> http://trac.osgeo.org/mapserver/wiki/PostGIS
> I realize this might be a mapserver mailing list qn, but thought that some of you might know the answer…it might be a simple syntax problem that I’ve missed…
> Thanks,
> Vishal
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110817/995c3d98/attachment.html>
