[postgis-users] connecting to postgis form mapserver
David Fawcett
david.fawcett at gmail.com
Wed Aug 17 19:33:17 PDT 2011
Vishal,
As Ben said, enabling debugging is the best way to figure out what is
going on.
There is some pretty good documentation on how to do that at:
http://mapserver.org/optimization/debugging.html
If that doesn't help you, it is probably time to move this over to the
MapServer list. (Where Ben and I will also be likely hanging out...)
David.
On Wed, Aug 17, 2011 at 7:44 PM, Ben Madin
<lists at remoteinformation.com.au> wrote:
> Vishal,
> David has probably nailed this one, but if not or otherwise you might also
> want to put DEBUG ON into your map and the LAYER definitions (you need both)
> - the debug output from postgis connections is comprehensive if a little
> complex initially, but very useful for learning.
> It doesn't hurt to explicitly set projections as well, to make sure they
> match.
> cheers
> Ben
> On 18/08/2011, at 4:09 AM, Vishal Mehta wrote:
> Hi all,
> I am testing out mapserver-postgis and a simple test is returning an empty
> map. Here is my map file
> MAP
> IMAGETYPE PNG
> EXTENT 77.5 12.95 77.7 13.01
> SIZE 550 450
> IMAGECOLOR 255 255 255
> SHAPEPATH "../data"
> # Start of LAYER DEFINITIONS-------------------------------
> LAYER
> CONNECTIONTYPE POSTGIS
> NAME "wards"
> # Connect to a remote spatial database
> CONNECTION "host=localhost port=5432 dbname=empty
> user=postgres password=xxx"
> # Get the lines from the 'geom' column of the 'wards'
> table
> DATA 'geom from "myschema.wards198" using srid=4326 using
> unique gid'
> STATUS ON
> TYPE POLYGON
> CLASS
> NAME "wards"
> STYLE
> OUTLINECOLOR 255 0 0
> END
> END
> END
> # End of LAYER DEFINITIONS -------------------------------
> END
> And the html that calls it
> <html>
> <head>
> <title>my postgis map</title>
> </head>
> <body bgcolor=white>
> <center>
> <br>
> <table width=570>
> <tr>
> <td>
> <br>
> <img width=550 height=450
> src=/cgi-bin/mapserv.exe?map=C:\OSGeo4W/apps/mapserver-tutorial/mytests/example.map&mode=map
> border=1>
> </td>
> </tr>
> </table>
> <br>
> </body>
> </html>
> Other info:
> Platform:
> - Windows 7, postgresql9 , postgis 2.0
> - I installed Mapserver separately through the OSGEO4 installer.
> - I can connect to the same database through php
> - I can create simple mapserver apps using shapefiles etc alright
> (e.g. same map file above, calling a shapefile, works fine)
> - Mapserv.exe –v shows that it was installed with postgis support.
> - Also can Mapserver handle postgis Mulipolygon geometry ok?
> I did check most of the points here which seemed ok ( i did not check those
> in this list that I don’t really know how to in Windows ).
> http://trac.osgeo.org/mapserver/wiki/PostGIS
> I realize this might be a mapserver mailing list qn, but thought that some
> of you might know the answer…it might be a simple syntax problem that I’ve
> missed…
> Thanks,
> Vishal
> postgis-users mailing list
