[postgis-users] ERROR: geometry contains non-closed rings
Ben Madin
lists at remoteinformation.com.au
Thu Aug 18 09:34:53 PDT 2011
G'day Puneet,
Maybe you could start with :
SELECT gid, st_isvalidreason(the_geom), st_summary(the_geom) FROM data WHERE st_isclosed(the_geom) is FALSE;
cheers
Ben
On 19/08/2011, at 12:19 AM, Mr. Puneet Kishor wrote:
> I loaded a bunch of data (that came from ArcMap) into PostGIS (1.5.3) via shp2pgsql and am trying to draw it with MapServer 6.0.1. I get
>> msDrawMap(): Image handling error. Failed to draw layer named 'foo'.
>> msPostGISLayerWhichShapes(): Query error. Error (ERROR: geometry contains non-closed rings )
> Many thanks in advance for your suggestions.
> Puneet Kishor
> postgis-users mailing list
