[postgis-users] How to extract multiple convex hulls from a query?
Stephen Woodbridge woodbri at swoodbridge.com
Wed Aug 24 06:38:00 PDT 2011
Hi all,
I am trying to construct multiple convex hulls from a series of point
where  I have an attribute dist for each point.
What I want is to generate convex hulls for expanding rings where dist
<= slice up to some max_dist.
So if slice=100 and max_dist=500, then each hull would be:
1. all points <= 100
2. all points <= 200
3. all points <= 300
4. all points <= 400
5. all points <= 500
So I have a procedure that generates the points and is fairly costly to
run. I would like to run it once and extract all the hulls in a single
pass if possible.
I'm currently running postgresql 8.3 and "POSTGIS="1.5.1"
GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.6.32" USE_STATS"
Any thoughts or snippets would be appreciated.
Thanks,
   -Steve
