[postgis-users] How configure postgis to enable the rasters.
Bborie Park bkpark at ucdavis.edu
Wed Aug 24 15:07:43 PDT 2011
Are you able to load the GDAL python module through python?  Try the
following in python:
from osgeo import gdal
If the above doesn't work, the GDAL python module may not be located in
any of the default module paths expected by python.  You may need to
specify the environmental variable PYTHONPATH to include the path to the
GDAL python module.
-bborie
On 08/24/2011 01:54 PM, Andrea Peri wrote:
> Hi,
> I'm try-ing to configure (for compile) the postgis-svn to enable use of the
> rasters.
> To do this I add in the configure phase the option " --with-raster ".
> And also the option:
> --with-gdalconfig=/usr/local/bin/gdal-config
> But I have this error:
> checking for pj_get_release in -lproj... yes
> GUI: Build requested, checking for dependencies (GKT+2.0)
> checking for pkg-config... /usr/bin/pkg-config
> checking for GTK+ - version>= 2.8.0... yes (version 2.18.9)
> TOPOLOGY: Topology support requested
> RASTER: Raster support requested
> checking for GDAL>= 1.6.0... found
> checking for GDALFPolygonize in -lgdal... no
> checking for GDAL Python bindings... not found
> configure: error: GDAL Python bindings required by raster2pgsql.py loader
> This sound strange to me.
> Infact
> when install gdal from source I have add the option" --with-python"
> and the configure , compile and install was ended without error and all seem
> was correctly installed.
> As reported from the log of configure on gdal
>   Poppler support:           no
>    Podofo support:            no
>    OpenCL support:            no
>    Armadillo support:         no
>    SWIG Bindings:          python
>    Statically link PROJ.4:    no
>    enable OGR building:       yes
>    enable pthread support:    yes
>    enable POSIX iconv support:yes
> I also check if there was other versions of gdal in the machine.
> So I'm don't know what miss to my settings.
> There is some docs about the settings need for raster extension?
> Thx,
> Andrea.
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
