[postgis-users] How configure postgis to enable the rasters.
Andrea Peri
aperi2007 at gmail.com
Thu Aug 25 04:03:45 PDT 2011
>Adding /usr/local/lib to PYTHONPATH won't help much since python knowns
>where the GDAL python module but can't find the GDAL library itself.
>Is /usr/local/lib in the linker path? You may want to check
>/etc/ld.so.conf to see if /usr/local/lib is in there. If not, add
>/usr/local/lib to /etc/ld.so.conf and then run ldconfig. BUT, this may
>not be the best solution as you are running a 64-bit linux system.
>Since it looks like you compiled your own GDAL, you should reconfigure
>and recompile GDAL with something like:
>./configure --libdir=/usr/local/lib64 OTHER_CONFIG_FLAGS
>Reconfiguring and recompiling GDAL should work as I'm guessing that
>/usr/local/lib64 is in /etc/ld.so.conf but /usr/local/lib isn't.
Great !
Adding
/usr/local/lib to
ld.so.conf.d it worl perfectly !
thx a lot.
Andrea.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110825/f22ccbda/attachment.html>
