[postgis-users] Raster Points in Polygon (was Re: PostGIS Raster for Met Data)
Bryce L Nordgren bnordgren at fs.fed.us
Thu Aug 25 11:58:29 PDT 2011
postgis-users-bounces at postgis.refractions.net wrote on 08/25/2011 05:25:56
PM:
> > If I understand this right, SRID 900917 is a custom coordinate system
> > for the (i,j) pixel coordinates of the image? Wouldn't this mean that
> > you have to have a different SRID for every tile (raster) of the
> > image, since each tile starts with (1,1)?
> No. We deal with meteorological data rather than data images, and
> apart from topography data (which can be pretty massive), none of
> our raw data is tiled.
Understood. I think our issue is with the term "tile". If you store your
massive data in more than one (say N) database rows, then you require N
SRIDs to represent the N transforms from the within-the-tile coordinates
to real world coordinates. If, however, the within-the-tile coordinates
are first transformed to the (i,j) coordinates from the original grid
(e.g., the coordinates from before you loaded it into your database), then
you only need a single SRID. I did not see such a transformation in my
cursory examination of the code posted to the list.
Even without a formal definition, the unique SRIDs should be used to
distinguish between within-the-tile coordinates from different tiles
(database rows). You'll then need another SRID to represent "original
grid" coordinates.
Bryce
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110825/07b5162d/attachment.html>
