[postgis-users] "Erase" and "Intersect" performance questions - PostGIS way slower than ArcGIS
Paul Ramsey pramsey at opengeo.org
Thu Aug 25 15:53:20 PDT 2011
No thoughts, you're turning up expected results, I'd say. Arc is a
GIS, PostGIS is a database. I'm sure we could get much better
performance on your workload if we added the intersection operation
into the prepared geometry concept, but that would be quite a bit of
work I'm sure.
P.
On Thu, Aug 25, 2011 at 2:56 PM, Sheara Cohen <Sheara at calthorpe.com> wrote:
> Hey Chris – Thanks for your response.
> With regard to ST_Difference, what I was trying to accomplish is a
> “deletion” or  “clipping out” of rivers and lakes from a parcel file. Both
> are vector files. Based on your description, it sounds like I’m using the
> wrong query. Do you know which one I should be using?
> And with regard to both the ST_Intersection and ST_Difference… yes, I am
> using vector files with HUGE, complex polygons that spread over very large
> areas (hundreds of miles). I can dice these in ArcGIS or something like that
> before throwing the files over the fence into Postgres. But I’m still
> confused by the fact that similar operations run so quickly on the exact
> same files in ArcGIS. I feel like there is something I’m totally missing
> about how to set up these queries correctly in PostGIS.
> If you or anyone have any last thoughts, I’d be really interested.
> Thanks again,
> ~ Sheara
> Sheara Cohen
> Planner
> C A L T H O R P E  A S S O C I A T E S
> 2095 ROSE STREET, SUITE 201, BERKELEY, CALIFORNIA, 94709 USA
> 510 809-1165 (direct) | 510-548-6800 x35 (main) | 510 548-6848 (fax)
> sheara at calthorpe.com | www.calthorpe.com
> postgis-users mailing list
