[postgis-users] Longitude and latitude ranges
Ture PĂ„lsson ture.palsson at gmail.com
Mon Aug 29 23:11:05 PDT 2011
2011/8/29 Jaime Casanova <jaime at 2ndquadrant.com>:
>> Perhaps this is a too-obvious question, but have you made sure that
>> you don't have some "bad" point, with latitude and/or longitude out of
>> range, that has somehow sneaked into your data set?
> if i create geometry points it works like a charm, so i don't think so
The geometry datatype does very little in terms of sanity checks, it
will happily let you create all sorts of bizarre coordinates:
idf=> select st_asewkt(st_setsrid(st_makepoint(1000, 1000), 4326));
        st_asewkt
SRID=4326;POINT(1000 1000)
(1 row)
However, try to cast one of those to geography, and you're in trouble:
idf=> select st_asewkt(st_setsrid(st_makepoint(1000, 1000), 4326))::geography;
ERROR:  Coordinate values are out of range [-180 -90, 180 90] for GEOGRAPHY type
 -- T
