[postgis-users] Geocoding cross streets?
Aren Cambre aren at arencambre.com
Thu Dec 1 06:20:38 PST 2011
My question is already answered: someone committed changes at
http://trac.osgeo.org/postgis/ticket/1333#comment:3.
Are these already in the SVN trunk?
Aren
On Wed, Nov 30, 2011 at 6:29 PM, Aren Cambre <aren at arencambre.com> wrote:
> Based on the conversation below, it appears there is already a solution,
> and people well-versed with PostGIS may be helping with this already. Given
> that, are my n00b skillz of much use?
> Second question--when might this cross street feature be available? I am
> asking for selfish reasons--I am working on a praxis and have thousands of
> cross streets I need to geocode.
> Aren
> On Tue, Nov 29, 2011 at 12:03 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 11/29/2011 12:42 PM, Stephen Frost wrote:
>>> * Stephen Woodbridge (woodbri at swoodbridge.com) wrote:
>>>> I currently have some lists of names that are converted to optimized
>>>> pcre regular expressions. I uses these to help separate the street
>>>> from the city name. The lists are only used to create header files
>>>> that contain the regular expressions that get compiled into the
>>>> code. The idea being that these names are reasonably static for a
>>>> given data set.
>>> Ah, ok, I see.  When converting this to a PG function, I'd probably want
>>> to go ahead and pull those lists from the TIGER data set and compile the
>>> regexps on PG backend startup instead.  Does it handle misspelled names
>>> or do any kind of "sounds like" searching on the city names?  I'm
>>> guessing 'no', but figured I'd ask anyway..
>> The lists that I have generated are pulled from a number of sources, like
>> the actual tiger data, the fips 4-2 placenames, I also have some common
>> abbreviations, and misspellings, but it is not doing any sounds like
>> searching. I think that I broke the regular expressions into separate state
>> specific regular expressions because putting them all into a sine
>> expression exceeded some limit in pcre.
>> The regex expressions are created in perl and are highly optimized. You
>> probably can not read the regex's and make much sense out of them, but they
>> are extremely efficient to evaluate.
>> Also you can take just that directory from PAGC and build it and it
>> should create a command line executable that you can test with and run it
>> in the debugger and valgrind, etc. Something like:
>> cd parseaddress
>> ./configure
>> make
>> ./parseaddress 101 W MLK AVE NORTH CHELMSFORD MA 01863
>> -Steve
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111201/ead6169b/attachment.html>
