[postgis-users] Raster pixel value
Andreas Forø Tollefsen
andreasft at gmail.com
Thu Dec 1 06:43:35 PST 2011
This is great! Fantastic. I will do some testing.
2011/12/1 Tom van Tilburg <tom.van.tilburg at gmail.com>
> Pierre,
> This is great you're working on this. It is exactly what I think that
> pgraster is going to make a great tool.
> Last days I didn't really have time to check out things, hopefully this
> week.
> Cheers,
> Tom
> On 30-11-2011 19:19, Pierre Racine wrote:
>> Andreas, Tom,
>> I have put two new functions you might be interested by in
>> http://trac.osgeo.org/postgis/**browser/trunk/raster/scripts/**plpgsql<http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql>
>> The first one, st_areaweightedsummarystats.**sql, is usefull when you
>> want to compute summary stats (like the weighted mean) of values coming
>> from a raster table for a series of polygons and that you use
>> ST_Intersection(raster, geometry) to compute the intersection. You normally
>> use it this way:
>> SELECT gt.id,
>> (aws).count,
>> (aws).distinctcount,
>> (aws).geom,
>> (aws).totalarea,
>> (aws).meanarea,
>> (aws).totalperimeter,
>> (aws).meanperimeter,
>> (aws).weightedsum,
>> (aws).weightedmean,
>> (aws).maxareavalue,
>> (aws).minareavalue,
>> (aws).maxcombinedareavalue,
>> (aws).mincombinedareavalue,
>> (aws).sum,
>> (aws).mean,
>> (aws).max,
>> (aws).min
>> FROM (SELECT ST_AreaWeightedSummaryStats(**gv) aws
>> FROM (SELECT ST_Intersection(rt.rast, gt.geom) gv
>> FROM rasttable rt, geomtable gt
>> WHERE ST_Intersects(rt.rast, gt.geom)
>> ) foo
>> GROUP BY gt.id
>> ) foo2
>> The second one, st_summarystatsagg.sql, serve the same purpose but when
>> you are using ST_MapAlgebra() (soon ST_Clip()) to compute the intersection.
>> you normally use it like this:
>> SELECT (ss).count,
>> (ss).sum,
>> (ss).mean,
>> (ss).min,
>> (ss).max
>> FROM (SELECT ST_SummaryStatsAgg(gv) ss
>> FROM (SELECT ST_Clip(rt.rast, gt.geom) gv
>> ) foo
>> GROUP BY gt.id
>> ) foo2
>> This is very equivalent to what you were doing. The ST_Clip() replace the
>> ST_MapAlgebra() part and the ST_SummaryStatsAgg() replace the
>> ST_SummaryStats(ST_Union()) part. This should be faster since it does a
>> ST_Union() less.
>> I'm working on a plpgsql version of ST_Clip(). I will post it very soon.
>> Pierre
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111201/8613497c/attachment.html>
