[postgis-users] Summarizing the temperature values for a buffer within my tables
Bborie Park
bkpark at ucdavis.edu
Sun Dec 4 11:08:58 PST 2011
On Fri, Dec 2, 2011 at 10:30 AM, maduako ikechukwu <iykemadu84 at gmail.com> wrote:
> Hi Piere,
> Thanks for yesterday, right now am trying to summarize the temperature
> values within a particular buffer just like you did in the tutorial using
> the codes below but it seems troublesome.
> could you help me please. I dont have to create tables one after the other
> like you did in the tutorial becuase I dont have that priveledge , so I have
> to only write a select statement to do that.
> Here is my code:
> SELECT I.temp_lst_id, meantemp
> From (Select sum(ST_Area(the_geom)*val)/(sum(ST_Area(the_geom))) AS
> meantemp, I.temp_lst_id
> From (Select(ST_Intersection(R.rast,(ST_Transform(ST_Buffer(I.the_geom,
> 100), 32613)))).geom AS the_geom,
> (ST_Intersection(R.rast,(ST_Transform(ST_Buffer(I.the_geom, 100),
> 32613)))).val AS val
> FROM in_situ_lst I, lst_utm_day R
> WHERE the_geom && R.rast
> AND ST_Intersects(R.rast,the_geom)
> AND I.temp_lst_id = 2
> )) foo;
> the Error in this code is "ERROR: subquery in FROM must have an alias
> LINE 3: From (Select(ST_Intersection(R.rast,(ST_Transform(ST_Buffer(..."
> Regards.
> Iyke Maduako
> Masters in Geospatial Technologies
> Institute for Geoinformatics,IfGI
> University of Muenster Germany
> Phone: +4915129048460
> Alternative Email:iykefirstclass at yahoo.com
You need to give an alias to your second sub-query.
SELECT
I.temp_lst_id,
meantemp
>From (
From
Select
) BAR
) foo;
In your query (reformatted), I added the BAR for the second subquery.
-bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
