[postgis-users] Raster pixel value
Tom van Tilburg
tom.van.tilburg at gmail.com
Sun Dec 4 11:09:36 PST 2011
Pierre,
I just ran a test to see the difference between my old method and your
new method with ST_Clip and ST_SummaryStatsAgg and came up with the
following:
1. The old way took 38 secs. whereas the new one 46 (100 polygons,
usually covering part of 1 raster tile).
2. ST_Clip appears to fill up nodatavalues with zero as soon as they
fall within the polygon. I have been staring a while at your code but
couldn't really see what caused this. I thought it might be a wrong
MinPossibleVal but it doesn't seem to be.
Cheers,
Tom
On 30-11-2011 19:19, Pierre Racine wrote:
> Andreas, Tom,
> I have put two new functions you might be interested by in
> http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql
> The first one, st_areaweightedsummarystats.sql, is usefull when you want to compute summary stats (like the weighted mean) of values coming from a raster table for a series of polygons and that you use ST_Intersection(raster, geometry) to compute the intersection. You normally use it this way:
> SELECT gt.id,
> (aws).count,
> (aws).distinctcount,
> (aws).geom,
> (aws).totalarea,
> (aws).meanarea,
> (aws).totalperimeter,
> (aws).meanperimeter,
> (aws).weightedsum,
> (aws).weightedmean,
> (aws).maxareavalue,
> (aws).minareavalue,
> (aws).maxcombinedareavalue,
> (aws).mincombinedareavalue,
> (aws).sum,
> (aws).mean,
> (aws).max,
> (aws).min
> FROM (SELECT ST_AreaWeightedSummaryStats(gv) aws
> FROM (SELECT ST_Intersection(rt.rast, gt.geom) gv
> FROM rasttable rt, geomtable gt
> WHERE ST_Intersects(rt.rast, gt.geom)
> ) foo
> GROUP BY gt.id
> ) foo2
> The second one, st_summarystatsagg.sql, serve the same purpose but when you are using ST_MapAlgebra() (soon ST_Clip()) to compute the intersection. you normally use it like this:
> SELECT (ss).count,
> (ss).sum,
> (ss).mean,
> (ss).min,
> (ss).max
> FROM (SELECT ST_SummaryStatsAgg(gv) ss
> FROM (SELECT ST_Clip(rt.rast, gt.geom) gv
> ) foo
> GROUP BY gt.id
> ) foo2
> This is very equivalent to what you were doing. The ST_Clip() replace the ST_MapAlgebra() part and the ST_SummaryStatsAgg() replace the ST_SummaryStats(ST_Union()) part. This should be faster since it does a ST_Union() less.
> I'm working on a plpgsql version of ST_Clip(). I will post it very soon.
> Pierre
> postgis-users mailing list
