[postgis-users] Preparing for Topology - St_CreateTopoGeo
Chris English sglish at hotmail.com
Sun Dec 4 15:55:56 PST 2011
Looking for triggers town by town
-- Executing query:select topology.createtopology('bh_parcels', 32011);"Topology bh_parcels populated"Not that town
4887 rows in, 13533 edge rows out 4888 face rows 8917 nodes out________________________________
> From: sglish at hotmail.com
> To: postgis-users at postgis.refractions.net
> Date: Sat, 3 Dec 2011 13:22:32 -0500
> Subject: Re: [postgis-users] Preparing for Topology - St_CreateTopoGeo
> in any case, to your point of trying to isolate a portion that triggers
> a bug in
> St_CreateTopoGeo, some candidates are suggested by taking the geoms
> reported as Error initially:
> select gid, mun from unioncountyparcels where geom &&
> ST_AsEWKT('01060000200B7D00000100000001030000000100000007000000204F2F7CE23C214140AA79907071244180EF6AE12B3D2141C0EF55BC50712441E0ACD564CC3C21414008958C7470244140F668FF823C2141C0C2B86094702441E0C3B6D3A23C21414066FBC5DD702441607EDAA7C23C2141C006372B27712441204F2F7CE23C214140AA799070712441')
> (later-> possible_triggers_2)
> gid____mun
> 37854;"2004"
> 27568;"2004"
> 31314;"2004"
> 32373;"2004"
> 34949;"2004"
> 36301;"2004"
> 36303;"2004"
> 37096;"2004"
> 133778;"2019"
> 133779;"2019"
> or
> ST_AsEWKT('01060000200B7D0000010000000103000000010000000500000080CD197443872141804C827B8B72244160C59F12AC872141007C974465722441200CCDF85687214100F7FE58B6712441006624DF018721410032D76ED571244180CD197443872141804C827B8B722441');
> (later -> possible_triggers)
> gid_____mun
> 25221;"2004"
> 32369;"2004"
> 34946;"2004"
> 34947;"2004"
> 34948;"2004"
> select topology.createtopology('possible_triggers', 32011);
> Select topology.ST_createtopogeo('possible_triggers',St_collect(geom))
> from possible_triggers;
> <this populated for the second group>
> "Topology possible_triggers (3), SRID 32011, precision 0
> 8 nodes, 12 edges, 5 faces, 0 topogeoms in 0 layers"
> Select
> topology.ST_createtopogeo('possible_triggers_2',St_collect(geom)) from
> possible_triggers_2;
> "Topology possible_triggers_2 populated"
> Well, that approach didn't isolate.  Better thoughts on isolating?
> Chris
> Date: Sat, 3 Dec 2011 09:22:29 -0500
> strk,
> I think that's the next, next step, first I have to figure out the
> final update
> of my topo tables and the topology documentation has left me head
> scratching, i.e. the topology.CreateTopoGeom stage:
> select edge_id, start_node, end_node, next_left_edge,
> abs_next_left_edge, next_right_edge,
> abs_next_right_edge, left_face, geom from union_cty_topo.edge_data limit 1;
> 20952;271096;271075;20954;20954;-20953;20953;0;"01020000200B7D00000200000060C7D31DEF042041807D82545CA72441C087CB2AB504204140C7FC7E07AA2441"
> select face_id, mbr from union_cty_topo.face limit 2;
> 0;""
> 7447;"01030000200B7D00000100000005000000C087CB2AB5042041807D82545CA72441C087CB2AB5042041C0E1276882AC2441E06B43906F082041C0E1276882AC2441E06B43906F082041807D82545CA72441C087CB2AB5042041807D82545CA72441"
> select node_id, containing_face, geom from union_cty_topo.node limit 1;
> 271075;;"01010000200B7D0000C087CB2AB504204140C7FC7E07AA2441"
> select topogeo_id, layer_id, element_id,element_type from
> union_cty_topo.relation limit 1;
> <no data>
> select gid, pams_pin, cost, topo  from union_cty_topo.summit_parcels limit 1;
> <no data>
> So I take the fact that I don't have node_id.containing_face, and no
> data in either
> relation or summit_parcels as my failure to understand this final step
> of CreateTopoGeom
> update union_cty_topo.summit_parcels as sp   -- sp is  summit_parcels
>      set topo = topology.createtopoGeom('union_cty_topo',
>              3,1
>              , foo.sfaces)
> from (Select s.gid,
> topology.TopoElementaryArray_Agg(Array[f.face.id,3]) as sfaces
>          From union_cty_topo.summit_parcels as s
>              Inner Join union_cty_topo.face as f on s.topo && f.mbr -- a
> little confusion here
>          where ST_Covers (s.geom,
> topology.ST_GetFaceGeometry('union_cty_topo', f.face_id))
>              Group by s.gid) as foo
> Where foo.gid =sp.gid;
> ERROR:  schema "f" does not exist
> Chris
> --switched to firefox from chrome in hopes of better plain text client
>  > Date: Sat, 3 Dec 2011 09:44:37 +0100
>  > From: strk at keybit.net
>  > On Fri, Dec 02, 2011 at 10:53:16PM -0500, Chris English wrote:
>  > > SELECT topology.st_createtopogeo('union_cty_topo',ST_Collect(geom))
>  > > FROM summit_parcels;
>  > > "Topology union_cty_topo populated"
>  > Great ! Congratulations !
>  > Now maybe you would want to try with another subset of the data
>  > as I think you were trying to isolate a portion of it that triggers
>  > a bug in ST_CreateTopoGeo, right ?
>  > --strk;
>  > ,------o-.
>  > | __/ | Thank you for PostGIS-2.0 Topology !
>  > | / 2.0 | http://www.pledgebank.com/postgistopology
>  > `-o------'
>  > _______________________________________________
>  > postgis-users mailing list
>  > http://postgis.refractions.net/mailman/listinfo/postgis-users
> _______________________________________________ postgis-users mailing
> list postgis-users at postgis.refractions.net
