[postgis-users] parsing postgis answers
Birgit Laggner
birgit.laggner at vti.bund.de
Mon Dec 5 03:58:27 PST 2011
Hi Michal,
you could use a combination of st_xmin, st_ymin, st_xmax and st_ymax
instead of st_extent. They will provide you with the same coordinates as
st_extent but in a numeric data type.
Hope that helps,
Birgit.
Am 05.12.2011 12:26, schrieb Micha? Droz.dz.:
> Hi List!
> I am fresh Postgis user and have a problem with ST_EXTENT. I am using
> it to get data for map.zoomToExtent in openLayers.
> The problem is that zoomToExtens takes parameters as
> zoomToExtent(value,value,value,value)
> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html#OpenLayers.Map.zoomToExtent
> from ST_EXTENT a receive WKT like this:
> "BOX(2294970.88258299 6588308.80462897,2295532.89622321 6588616.7042758)"
> How to parse that answer to get paremeters for OpenLayers in
> appropirate format?
> I checked that OpenLayers is able to parse WKT but it is impossible
> with BOX type.
> http://dev.openlayers.org/docs/files/OpenLayers/Format/WKT-js.html
> Thank for help!
> Michal
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111205/cf79372a/attachment.html>
