[postgis-users] ERROR: pt_in_ring_2d: V[n] != V[0]
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 8 08:42:35 PST 2011
Hi all,
I'm getting this error:
select gid from parcels where not isvalid(the_geom);
ERROR: pt_in_ring_2d: V[n] != V[0] (-83.5001 38.244 != -83.5001 38.244)
********** Error **********
SQL state: XX000
select gid, st_isvalidreason(the_geom) from parcels where not
isvalid(the_geom);
NOTICE: IllegalArgumentException: Invalid number of points in
LinearRing found 3 - must be 0 or >= 4
ERROR: POSTGIS2GEOS conversion failed
SQL state: XX000
"POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.6.32" USE_STATS"
This just seems very bad in that isvalid() and st_isvalidreason() should
never fail, IMO.
-Steve
