[postgis-users] Efficient ways to query PostGIS Raster pixel values using Intersects
Andrew Hill
andrew at vizzuality.com
Thu Dec 8 09:25:10 PST 2011
I've been working on some projects where we would like to find the values
for pixels in a defined area. From what I can find, these sorts of queries
have a couple of options. First, finding all tiles that intersect your
polygon, then converting all pixels to geoms and performing a second
ST_Intersects. Another (and from my attempts the faster of the two), is to
perform the first intersects and then doing an XY walk of the pixels. I
have an example here,
https://gist.github.com/1353427
My problem is that we still aren't finding good methods for doing these
queries fast. It gets more complex. Take for example,
SELECT rid,ST_AsText(ST_Centroid(rast)) FROM marso WHERE
ST_Intersects(rast, GEOMETRYFROMTEXT('MULTIPOLYGON(((10 10, 10 0, 0 0, 0
10, 10 10)))',4326))
(marso is an indexed 3600x1800 4326 global raster tiled at 100x100)
As expected, I get back a row for every tile my polygon intersects. Now, if
I want to use those results for display, I can swap in an ST_AsPNG. Here is
where it gets silly, I still get my 4 tiles, all fully converted to PNG
(not cropped). So, I have to clip them. Right now, and from the ST_Clip I
have seen, this isn't going to be very efficient. It will require either XY
walks or complete pixel->geom conversions to resample the tile. Also, if I
want to use the result for display, the mechanisms for downsampling are
nascent. Downsampling a tile for example in this scenario would take both
an ST_Resample and an ST_Clip, and from what I've done, resulting in a
really inefficient query.
Here is an example of the SQL to do so and then ST_Clip function used,
sql: https://gist.github.com/1447684
clip: https://gist.github.com/1447686
So. I'm just curious what sorts of optimizations either (a) I'm missing for
indexing, reshaping, and returning pixel values and pixels-in-area etc., or
(b) are in the pipeline? What can we expect from the raster libraries in
the future? (I'll save questions related to the merging of result tiles for
a later thread). For web development, speed is directly tied to user
experience, so it is really important to our plans for using the Raster
libraries in future work and we'd love to help find some solutions.
cheers,
Andrew
Andrew W. Hill
www.vizzuality.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111208/98596aa5/attachment.html>
