[postgis-users] ERROR: pt_in_ring_2d: V[n] != V[0]
Sandro Santilli strk at keybit.net
Fri Dec 9 03:30:00 PST 2011
On Thu, Dec 08, 2011 at 03:48:13PM -0500, Stephen Woodbridge wrote:
> Upgraded to PostGIS 1.5.3 and get the same problem.
> select gid, st_isvalidreason(the_geom) from parcels where not
> isvalid(the_geom);
> ERROR:  POSTGIS2GEOS conversion failed
Sounds like a dejavu here. Maybe I fixed this in 2.0 only,
where you also have tools to clean your geometry.
For now I wouldn't consider it an urgent bug unless you're
unable to dump your table for upgrading to 2.0.
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
