[postgis-users] geocode_intersection (was How to update your SVN copy of PostGIS)
Aren Cambre
aren at arencambre.com
Sun Dec 11 16:32:14 PST 2011
I think that was it! Ran the *upgrade_geocode.sql *script against my DB,
and now I have the *geocode_intersection* function.
*However,* I'm getting no results with* geocode_intersection*. For example:
*SELECT **
*FROM geocode_intersection('ross', 'harwood', 'tx', 'dallas')*
I get a blank result set.
However, if I geocode a known address at that intersection, I get a valid
*SELECT addy, ST_X(ST_SetSRID(geomout,4326)),
ST_Y(ST_SetSRID(geomout,4326)), rating*
*FROM geocode('1928 ross ave, dallas, tx');*
Still investigating...
Aren
On Sat, Dec 10, 2011 at 6:17 PM, Aren Cambre <aren at arencambre.com> wrote:
> Ah, I see the problem now. I was thinking I'd have to reinstall all of
> PostGIS 2.0 to get the *geocode_intersection* function, but looking at
> http://trac.osgeo.org/postgis/changeset/8276, I realize that it's the *
> tiger_geocoder* extras package as you mention below.
> So I looked at the *upgrade_geocode.sql* script (
> http://trac.osgeo.org/postgis/browser/trunk/extras/tiger_geocoder/tiger_2010/upgrade_geocode.sql?rev=8276),
> and I guess this may help make sure I have the latest geocoding functions
> in my DB.
> I'll try this and see what happens.
> Aren
> On Sat, Dec 10, 2011 at 5:58 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Ok, just checking.
>> http://svn.osgeo.org/postgis/**trunk/extras/tiger_geocoder/**tiger_2010/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/>
>> Looks like something like this might do it:
>> cd /usr/share/postgresql/contrib
>> # edit create_geocode.sh
>> # then run it
>> ./create_geocode.sh
>> or just load them from here:
>> tiger_2010/geocode/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/geocode/>
>> browse about and install what you need.
>> -Steve W
>> On 12/10/2011 6:25 PM, Aren Cambre wrote:
>>> I refreshed the functions list and the parent DB and even opened/closed
>>> pgAdmin III. :-)
>>> I also ran this script:
>>> *SELECT * FROM pg_proc proc JOIN pg_language lang*
>>> *ON proc.prolang = lang.oid*
>>> *ORDER BY proname;*
>>> Double-checked myself with:
>>> *WHERE proname LIKE '%geocode%'*
>>> *ORDER BY proname;*
>>> Definitely no *geocode.** functions there.
>>> Aren
>>> On Sat, Dec 10, 2011 at 5:18 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>> wrote:
>>> Try right click on database and/or function list and refresh it.
>>> On 12/10/2011 6:15 PM, Aren Cambre wrote:
>>> Thanks.
>>> Now here's what I don't get: where are the *geocode* and
>>> *geocode_intersection* functions? If I look at the functions list
>>> in
>>> *spatial_db_template*'s *public* schema (using pgAdmin III),
>>> should I
>>> see those two? I thought they were included in the base PostGIS
>>> 2.0 product?
>>> Aren
>>> On Sat, Dec 10, 2011 at 5:09 PM, Stephen Woodbridge
>>> <mailto:woodbri at swoodbridge. com
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>> wrote:
>>> You can ignore all the notices. As long as you do not get a
>>> rollback, then things should be ok.
>>> The script is just trying to clean out potential obsolete
>>> functions
>>> that might be there if the database was created many
>>> versions ago
>>> and upgraded to this point.
>>> -Steve W
>>> On 12/10/2011 5:46 PM, Aren Cambre wrote:
>>> Thanks. Yup, I see it now. My mind was stuck in 3rd
>>> generation
>>> languages
>>> where things stop when you get an exception.
>>> The script's first gripe was that the *spatial_ref_sys*
>>> table
>>> already
>>> exists. Shouldn't it automatically kill and reload that
>>> table?
>>> Is that a
>>> bug?
>>> Anyway, I deleted it and reran the script. Now I get a
>>> bunch of
>>> notices
>>> about functions that don't exist. See attachment.
>>> It appears it's mostly not finding overloads of
>>> functions. E.g.,
>>> it says
>>> *populate_geometry_columns()* and
>>> oid)* are
>>> missing. I do have variants with different function
>>> signatures:
>>> *populate_geometry_columns( oid,boolean)* and
>>> *populate_geometry_columns( boolean)*.
>>> BTW, I'm trying to run this on my template PostGIS DB,
>>> which I named
>>> *spatial_db_template*.
>>> Aren
>>> On Sat, Dec 10, 2011 at 10:26 AM, Bborie Park
>>> <bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>
>>> <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>
>>> <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>>> wrote:
>>> Oops! My head is always in the raster world, so I
>>> just ran
>>> with the
>>> raster upgrade. Sorry about that.
>>> If you're getting an error, you'll want to scroll up
>>> past the
>>> transaction error message as the very first error
>>> message
>>> should be
>>> related to the actual statement that is failing.
>>> -bborie
>>> On Sat, Dec 10, 2011 at 6:47 AM, Aren Cambre
>>> <aren at arencambre.com <mailto:aren at arencambre.com>
>>> <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>
>>> <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>>**>
>>> wrote:
>>> > Thanks. Yesterday I
>>> found postgis_upgrade_20_minor.sql in
>>> /usr/share/postgresql/9.1/ contrib/postgis-2.0.
>>> > When I ran that, I got tons of errors like this:
>>> psql:/usr/share/postgresql/9.
>>> 1/contrib/postgis-2.0/postgis_
>>> upgrade_20_minor.sql:3235:
>>> > ERROR: current transaction is aborted, commands ignored
>>> until end of
>>> > transaction block
>>> > I see you mentioned rtpostgis_upgrade_20_minor. sql. Isn't that
>>> just for
>>> > raster functions? I searched my machine and cannot find it,
>>> anyway.
>>> > Aren
>>> > On Fri, Dec 9, 2011 at 10:02 PM, Bborie Park
>>> >> Aren,
>>> >> Since you're tracking trunk, after you've done the configure,
>>> make and
>>> >> make install, you'll want to run the upgrade script
>>> >> rtpostgis_upgrade_20_minor.sql
>>> >> Usually, the file is installed in the same place as
>>> rtpostgis.sql. If
>>> >> you can't find the upgrade file, you can find it in your
>>> checkout's
>>> >> directory at:
>>> >> raster/rt_pg
>>> >> -bborie
>>> >> On Fri, Dec 9, 2011 at 7:53 PM, Aren Cambre
>>> wrote:
>>> >> > Thanks. I got the latest SVN snapshot. I was able to
>>> configure, make,
>>> >> > and
>>> >> > make install. The problem is there seems to be missing steps
>>> between
>>> >> > building the whole thing and getting changes into my
>>> preexisting
>>> >> > PostGIS-enabled database.
>>> >> > Aren
>>> >> > On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park
>>> >> >> If you used something like...
>>> >> >> svn check out https://svn.osgeo.org/postgis/ trunk
>>> <https://svn.osgeo.org/ postgis/trunk
>>> <https://svn.osgeo.org/**postgis/trunk<https://svn.osgeo.org/postgis/trunk>
>>> >> >> You can safely run...
>>> >> >> svn update
>>> >> >> If that works, I'd recommend doing...
>>> >> >> svn cleanup
>>> >> >> -bborie
>>> >> >> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre
>>> >> >> wrote:
>>> >> >> > I admit this is a dumb question, but here it is.
>>> >> >> > I installed PostGIS on my Ubuntu 11.10 environment a few
>>> weeks ago
>>> >> >> > using
>>> >> >> > the
>>> >> >> > excellent instructions
>>> >> >> > at
>>> http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>> 2010-data
>>> <http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>> 2010-data
>>> <http://www.letseehere.com/**postgis-geocoder-using-tiger-**
>>> 2010-data<http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data>
>>> >> >> > Since then, the geocode_intersection function was added,
>>> and I need
>>> >> >> > it.
>>> >> >> > I'm
>>> >> >> > not clear what is the process of replacing the older
>>> snapshot of
>>> >> >> > PostGIS
>>> >> >> > with this newer one.
>>> >> >> > I don't see an obvious install/uninstall routine. I tried
>>> the soft
>>> >> >> > upgrade
>>> >> >> > at
>>> http://postgis.refractions. net/documentation/manual-svn/
>>> postgis_installation.html# upgrading
>>> <http://postgis.refractions. net/documentation/manual-svn/
>>> <http://postgis.refractions.**net/documentation/manual-svn/**
>>> postgis_installation.html#**upgrading<http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading>
>>> >> >> > but that didn't work. Do I need to do the hard upgrade
>>> each
>>> time I do
>>> >> >> > a
>>> >> >> > SVN
>>> >> >> > update?
>>> >> >> > Aren
>>> >> >> > ______________________________ _________________
>>> >> >> > postgis-users mailing list
>>> >> >> > postgis-users at postgis. refractions.net
>>> <http://refractions.net>
>>> <mailto:postgis-users at postgis. refractions.net
>>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>> <mailto:postgis-users at postgis <mailto:postgis-users at postgis>**.
>>> refractions.net <http://refractions.net>
>>> net/mailman/listinfo/postgis- users
>>> <http://postgis.refractions. net/mailman/listinfo/postgis- users
>>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**
>>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>>>
>>> >> >> Bborie Park
>>> >> >> Programmer
>>> >> >> Center for Vectorborne Diseases
>>> >> >> UC Davis
>>> >> >> 530-752-8380 <tel:530-752-8380> <tel:530-752-8380
>>> <tel:530-752-8380>> <tel:530-752-8380 <tel:530-752-8380>
>>> <tel:530-752-8380 <tel:530-752-8380>>>
>>> users
>>> users
>>> >> Bborie Park
>>> >> Programmer
>>> >> UC Davis
>>> >> postgis-users at postgis. refractions.net <
>>> users
>>> > postgis-users at postgis. refractions.net <http://refractions.net
>>> users
>>> Bborie Park
>>> Programmer
>>> UC Davis
>>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111211/934e33d7/attachment.html>
