[postgis-users] geocode_intersection (was How to update your SVNcopy of PostGIS)
Aren Cambre aren at arencambre.com
Sun Dec 11 18:17:29 PST 2011
That's it! Filed bug report at http://trac.osgeo.org/postgis/ticket/1366.
Now I don't know if this is a bug *per se*, but if I run this:
*SELECT addy, ST_X(ST_SetSRID(geomout,4326)),
ST_Y(ST_SetSRID(geomout,4326)), rating*
*FROM geocode_intersection('ross', 'harwood', 'TX', 'dallas')*
I get this:
*"(2001,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
*"(2000,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
*"(1999,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
*"(1998,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
It seems weird that I am getting four almost identical locations, each with
the same rating. The lat/long for this is dead on.
Aren
On Sun, Dec 11, 2011 at 8:06 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Aren,
> Try upper case TX.  I think we may have forgotten the logic to upper case
> the state.  We'll check that out.
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Aren Cambre
> *Sent:* Sunday, December 11, 2011 7:32 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] geocode_intersection (was How to update your
> SVNcopy of PostGIS)
> I think that was it! Ran the *upgrade_geocode.sql *script against my DB,
> and now I have the *geocode_intersection* function.
> *However,* I'm getting no results with* geocode_intersection*. For
> example:
>  *SELECT **
> *FROM geocode_intersection('ross', 'harwood', 'tx', 'dallas')*
>  I get a blank result set.
> However, if I geocode a known address at that intersection, I get a valid
> location:
> *FROM geocode('1928 ross ave, dallas, tx');*
> Still investigating...
> Aren
> On Sat, Dec 10, 2011 at 6:17 PM, Aren Cambre <aren at arencambre.com> wrote:
>> Ah, I see the problem now. I was thinking I'd have to reinstall all of
>> PostGIS 2.0 to get the *geocode_intersection* function, but looking at
>> http://trac.osgeo.org/postgis/changeset/8276, I realize that it's the *
>> tiger_geocoder* extras package as you mention below.
>> So I looked at the *upgrade_geocode.sql* script (
>> http://trac.osgeo.org/postgis/browser/trunk/extras/tiger_geocoder/tiger_2010/upgrade_geocode.sql?rev=8276),
>> and I guess this may help make sure I have the latest geocoding functions
>> in my DB.
>> I'll try this and see what happens.
>> Aren
>> On Sat, Dec 10, 2011 at 5:58 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> Ok, just checking.
>>> http://svn.osgeo.org/postgis/**trunk/extras/tiger_geocoder/**tiger_2010/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/>
>>> Looks like something like this might do it:
>>> cd /usr/share/postgresql/contrib
>>> # edit create_geocode.sh
>>> # then run it
>>> ./create_geocode.sh
>>> or just load them from here:
>>> tiger_2010/geocode/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/geocode/>
>>> browse about and install what you need.
>>> -Steve W
>>> On 12/10/2011 6:25 PM, Aren Cambre wrote:
>>>> I refreshed the functions list and the parent DB and even opened/closed
>>>> pgAdmin III. :-)
>>>> I also ran this script:
>>>> *SELECT * FROM pg_proc proc JOIN pg_language lang*
>>>> *ON proc.prolang = lang.oid*
>>>> *ORDER BY proname;*
>>>> Double-checked myself with:
>>>> *WHERE proname LIKE '%geocode%'*
>>>> *ORDER BY proname;*
>>>> Definitely no *geocode.** functions there.
>>>> Aren
>>>> On Sat, Dec 10, 2011 at 5:18 PM, Stephen Woodbridge
>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>>> wrote:
>>>>    Try right click on database and/or function list and refresh it.
>>>>    On 12/10/2011 6:15 PM, Aren Cambre wrote:
>>>>        Thanks.
>>>>        Now here's what I don't get: where are the *geocode* and
>>>>        *geocode_intersection* functions? If I look at the functions
>>>> list in
>>>>        *spatial_db_template*'s *public* schema (using pgAdmin III),
>>>>        should I
>>>>        see those two? I thought they were included in the base PostGIS
>>>>        2.0 product?
>>>>        Aren
>>>>        On Sat, Dec 10, 2011 at 5:09 PM, Stephen Woodbridge
>>>>        <mailto:woodbri at swoodbridge. com
>>>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>>> wrote:
>>>>            You can ignore all the notices. As long as you do not get a
>>>>            rollback, then things should be ok.
>>>>            The script is just trying to clean out potential obsolete
>>>>        functions
>>>>            that might be there if the database was created many
>>>>        versions ago
>>>>            and upgraded to this point.
>>>>            -Steve W
>>>>            On 12/10/2011 5:46 PM, Aren Cambre wrote:
>>>>                Thanks. Yup, I see it now. My mind was stuck in 3rd
>>>>        generation
>>>>                languages
>>>>                where things stop when you get an exception.
>>>>                The script's first gripe was that the *spatial_ref_sys*
>>>>        table
>>>>                already
>>>>                exists. Shouldn't it automatically kill and reload that
>>>>        table?
>>>>                Is that a
>>>>                bug?
>>>>                Anyway, I deleted it and reran the script. Now I get a
>>>>        bunch of
>>>>                notices
>>>>                about functions that don't exist. See attachment.
>>>>                It appears it's mostly not finding overloads of
>>>>        functions. E.g.,
>>>>                it says
>>>>                *populate_geometry_columns()* and
>>>>                oid)* are
>>>>                missing. I do have variants with different function
>>>>        signatures:
>>>>                *populate_geometry_columns( oid,boolean)* and
>>>>                *populate_geometry_columns( boolean)*.
>>>>                BTW, I'm trying to run this on my template PostGIS DB,
>>>>        which I named
>>>>                *spatial_db_template*.
>>>>                Aren
>>>>                On Sat, Dec 10, 2011 at 10:26 AM, Bborie Park
>>>>        <bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>
>>>>        <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>
>>>>        <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>>> wrote:
>>>>                    Oops!  My head is always in the raster world, so I
>>>>        just ran
>>>>                with the
>>>>                    raster upgrade.  Sorry about that.
>>>>                    If you're getting an error, you'll want to scroll up
>>>>        past the
>>>>                    transaction error message as the very first error
>>>>        message
>>>>                should be
>>>>                    related to the actual statement that is failing.
>>>>                    -bborie
>>>>                    On Sat, Dec 10, 2011 at 6:47 AM, Aren Cambre
>>>>        <aren at arencambre.com <mailto:aren at arencambre.com>
>>>>        <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>
>>>>        <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>>**>
>>>> wrote:
>>>>         > Thanks. Yesterday I
>>>>                    found postgis_upgrade_20_minor.sql in
>>>>                /usr/share/postgresql/9.1/ contrib/postgis-2.0.
>>>>         > When I ran that, I got tons of errors like this:
>>>>                    psql:/usr/share/postgresql/9.
>>>>        1/contrib/postgis-2.0/postgis_
>>>>                upgrade_20_minor.sql:3235:
>>>>         > ERROR:  current transaction is aborted, commands ignored
>>>>                until end of
>>>>         > transaction block
>>>>         > I see you mentioned rtpostgis_upgrade_20_minor. sql. Isn't
>>>> that
>>>>                    just for
>>>>         > raster functions? I searched my machine and cannot find it,
>>>>                anyway.
>>>>         > Aren
>>>>         > On Fri, Dec 9, 2011 at 10:02 PM, Bborie Park
>>>>         >> Aren,
>>>>         >> Since you're tracking trunk, after you've done the configure,
>>>>                    make and
>>>>         >> make install, you'll want to run the upgrade script
>>>>         >> rtpostgis_upgrade_20_minor.sql
>>>>         >> Usually, the file is installed in the same place as
>>>>                    rtpostgis.sql.  If
>>>>         >> you can't find the upgrade file, you can find it in your
>>>>                checkout's
>>>>         >> directory at:
>>>>         >> raster/rt_pg
>>>>         >> -bborie
>>>>         >> On Fri, Dec 9, 2011 at 7:53 PM, Aren Cambre
>>>> wrote:
>>>>         >> > Thanks. I got the latest SVN snapshot. I was able to
>>>>                    configure, make,
>>>>         >> > and
>>>>         >> > make install. The problem is there seems to be missing
>>>> steps
>>>>                    between
>>>>         >> > building the whole thing and getting changes into my
>>>>                preexisting
>>>>         >> > PostGIS-enabled database.
>>>>         >> > Aren
>>>>         >> > On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park
>>>>         >> >> If you used something like...
>>>>         >> >> svn check out https://svn.osgeo.org/postgis/ trunk
>>>>        <https://svn.osgeo.org/ postgis/trunk
>>>>        <https://svn.osgeo.org/**postgis/trunk<https://svn.osgeo.org/postgis/trunk>
>>>>         >> >> You can safely run...
>>>>         >> >> svn update
>>>>         >> >> If that works, I'd recommend doing...
>>>>         >> >> svn cleanup
>>>>         >> >> -bborie
>>>>         >> >> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre
>>>>         >> >> wrote:
>>>>         >> >> > I admit this is a dumb question, but here it is.
>>>>         >> >> > I installed PostGIS on my Ubuntu 11.10 environment a few
>>>>                    weeks ago
>>>>         >> >> > using
>>>>         >> >> > the
>>>>         >> >> > excellent instructions
>>>>         >> >> > at
>>>>        http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>>>                2010-data
>>>>        <http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>>>        2010-data
>>>>        <http://www.letseehere.com/**postgis-geocoder-using-tiger-**
>>>> 2010-data<http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data>
>>>>         >> >> > Since then, the geocode_intersection function was added,
>>>>                    and I need
>>>>         >> >> > it.
>>>>         >> >> > I'm
>>>>         >> >> > not clear what is the process of replacing the older
>>>>                    snapshot of
>>>>         >> >> > PostGIS
>>>>         >> >> > with this newer one.
>>>>         >> >> > I don't see an obvious install/uninstall routine. I
>>>> tried
>>>>                    the soft
>>>>         >> >> > upgrade
>>>>         >> >> > at
>>>>        http://postgis.refractions. net/documentation/manual-svn/
>>>>                postgis_installation.html# upgrading
>>>>        <http://postgis.refractions. net/documentation/manual-svn/
>>>>        <http://postgis.refractions.**net/documentation/manual-svn/**
>>>> postgis_installation.html#**upgrading<http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading>
>>>>         >> >> > but that didn't work. Do I need to do the hard upgrade
>>>> each
>>>>                    time I do
>>>>         >> >> > a
>>>>         >> >> > SVN
>>>>         >> >> > update?
>>>>         >> >> > Aren
>>>>         >> >> > ______________________________ _________________
>>>>         >> >> > postgis-users mailing list
>>>>         >> >> > postgis-users at postgis. refractions.net
>>>>        <http://refractions.net>
>>>>        <mailto:postgis-users at postgis. refractions.net
>>>>        <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>>        <mailto:postgis-users at postgis <mailto:postgis-users at postgis>**.
>>>>        refractions.net <http://refractions.net>
>>>>                net/mailman/listinfo/postgis- users
>>>>        <http://postgis.refractions. net/mailman/listinfo/postgis- users
>>>>        <http://postgis.refractions.**net/mailman/listinfo/postgis-**
>>>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>>>
>>>>         >> >> Bborie Park
>>>>         >> >> Programmer
>>>>         >> >> Center for Vectorborne Diseases
>>>>         >> >> UC Davis
>>>>         >> >> 530-752-8380 <tel:530-752-8380> <tel:530-752-8380
>>>>        <tel:530-752-8380>> <tel:530-752-8380 <tel:530-752-8380>
>>>>        <tel:530-752-8380 <tel:530-752-8380>>>
>>>>                users
>>>>                users
>>>>         >> Bborie Park
>>>>         >> Programmer
>>>>         >> UC Davis
>>>>         >> postgis-users at postgis. refractions.net <
>>>>                users
>>>>                users
>>>>                    Bborie Park
>>>>                    Programmer
>>>>                    UC Davis
>>>>    <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111211/6ee7b834/attachment.html>
