[postgis-users] geocode_intersection (was How to update yourSVNcopy of PostGIS)
Aren Cambre aren at arencambre.com
Mon Dec 12 10:13:32 PST 2011
Thanks. I was wondering about needing to do ST_SetSRID!
Trying the clustering now. I'm on 9.1, so the command for me is *CLUSTER
tiger_data.tx_edges USING tiger_data_tx_edges_the_geom_gist;*
Given 6.2 million rows, I'm expecting this to take a while! :-)
Aren
On Sun, Dec 11, 2011 at 8:40 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Aren,
> Forgot -- you don't need the ST_SetSRID call you have there.  It's doing
> nothing for you if you are just going to output the x and y coords.
> You might also want to try clustering your edges table
> CLUSTER tiger_data_tx_edges_the_geom_gist ON tiger_data.tx_edges;
> I haven't confirmed its absolutely better for the geocoder in all cases
> since it does do a lot of text checks, but I think the cross streets logic
> is more sensitive to it than other routines.  We are planning to do some
> more benchmarks
> on different versions of PostgreSQL to determine the optimal index to
> cluster on and then provide that as a maintenance function similar to the
> other ones we have listed in the docs.
> http://www.postgis.org/documentation/manual-svn/Extras.html#Tiger_Geocoder
> Regina
> http://www.postgis.us
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Paragon
> Corporation
> *Sent:* Sunday, December 11, 2011 9:28 PM
> *To:* 'PostGIS Users Discussion'
> *Subject:* Re: [postgis-users] geocode_intersection (was How to update
>  fixed.
> You get 4 because it interpolates 4 addresses at the 2 on one side and 2
> on the other where harwood cuts.  Since we aren't offsetting the point to
> the correct side of the street, it gives the same point for each.
> If you only care about the point, what you can do is just ask for the
> first result.
>  *SELECT addy, ST_X(ST_SetSRID(geomout,4326)),
> ST_Y(ST_SetSRID(geomout,4326)), rating*
> *FROM geocode_intersection('ross', 'harwood', 'TX', 'dallas', '', 1)*
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Aren Cambre
> *Sent:* Sunday, December 11, 2011 9:17 PM
> *To:* PostGIS Users Discussion
> your SVNcopy of PostGIS)
> That's it! Filed bug report at http://trac.osgeo.org/postgis/ticket/1366.
> Now I don't know if this is a bug *per se*, but if I run this:
> *FROM geocode_intersection('ross', 'harwood', 'TX', 'dallas')*
> I get this:
>  *"(2001,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
> *"(2000,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
> *"(1999,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
> *"(1998,,Ross,Ave,,,Dallas,TX,75201,t)";-96.799239;32.786929;3*
> It seems weird that I am getting four almost identical locations, each
> with the same rating. The lat/long for this is dead on.
> Aren
> On Sun, Dec 11, 2011 at 8:06 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Aren,
>> Try upper case TX.  I think we may have forgotten the logic to upper case
>> the state.  We'll check that out.
>> *Sent:* Sunday, December 11, 2011 7:32 PM
>> *Subject:* [postgis-users] geocode_intersection (was How to update your
>> SVNcopy of PostGIS)
>>  I think that was it! Ran the *upgrade_geocode.sql *script against my
>> DB, and now I have the *geocode_intersection* function.
>> *However,* I'm getting no results with* geocode_intersection*. For
>> example:
>>  *SELECT **
>> *FROM geocode_intersection('ross', 'harwood', 'tx', 'dallas')*
>>  I get a blank result set.
>> However, if I geocode a known address at that intersection, I get a valid
>> location:
>> *FROM geocode('1928 ross ave, dallas, tx');*
>> Still investigating...
>> Aren
>> On Sat, Dec 10, 2011 at 6:17 PM, Aren Cambre <aren at arencambre.com> wrote:
>>> Ah, I see the problem now. I was thinking I'd have to reinstall all of
>>> PostGIS 2.0 to get the *geocode_intersection* function, but looking at
>>> http://trac.osgeo.org/postgis/changeset/8276, I realize that it's the *
>>> tiger_geocoder* extras package as you mention below.
>>> So I looked at the *upgrade_geocode.sql* script (
>>> http://trac.osgeo.org/postgis/browser/trunk/extras/tiger_geocoder/tiger_2010/upgrade_geocode.sql?rev=8276),
>>> and I guess this may help make sure I have the latest geocoding functions
>>> in my DB.
>>> I'll try this and see what happens.
>>> Aren
>>> On Sat, Dec 10, 2011 at 5:58 PM, Stephen Woodbridge <
>>> woodbri at swoodbridge.com> wrote:
>>>> Ok, just checking.
>>>> http://svn.osgeo.org/postgis/**trunk/extras/tiger_geocoder/**
>>>> tiger_2010/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/>
>>>> Looks like something like this might do it:
>>>> cd /usr/share/postgresql/contrib
>>>> # edit create_geocode.sh
>>>> # then run it
>>>> ./create_geocode.sh
>>>> or just load them from here:
>>>> tiger_2010/geocode/<http://svn.osgeo.org/postgis/trunk/extras/tiger_geocoder/tiger_2010/geocode/>
>>>> browse about and install what you need.
>>>> -Steve W
>>>> On 12/10/2011 6:25 PM, Aren Cambre wrote:
>>>>> I refreshed the functions list and the parent DB and even opened/closed
>>>>> pgAdmin III. :-)
>>>>> I also ran this script:
>>>>> *SELECT * FROM pg_proc proc JOIN pg_language lang*
>>>>> *ON proc.prolang = lang.oid*
>>>>> *ORDER BY proname;*
>>>>> Double-checked myself with:
>>>>> *WHERE proname LIKE '%geocode%'*
>>>>> *ORDER BY proname;*
>>>>> Definitely no *geocode.** functions there.
>>>>> Aren
>>>>> On Sat, Dec 10, 2011 at 5:18 PM, Stephen Woodbridge
>>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>>>> wrote:
>>>>>    Try right click on database and/or function list and refresh it.
>>>>>    On 12/10/2011 6:15 PM, Aren Cambre wrote:
>>>>>        Thanks.
>>>>>        Now here's what I don't get: where are the *geocode* and
>>>>>        *geocode_intersection* functions? If I look at the functions
>>>>> list in
>>>>>        *spatial_db_template*'s *public* schema (using pgAdmin III),
>>>>>        should I
>>>>>        see those two? I thought they were included in the base PostGIS
>>>>>        2.0 product?
>>>>>        Aren
>>>>>        On Sat, Dec 10, 2011 at 5:09 PM, Stephen Woodbridge
>>>>>        <mailto:woodbri at swoodbridge. com
>>>>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>>>>> wrote:
>>>>>            You can ignore all the notices. As long as you do not get a
>>>>>            rollback, then things should be ok.
>>>>>            The script is just trying to clean out potential obsolete
>>>>>        functions
>>>>>            that might be there if the database was created many
>>>>>        versions ago
>>>>>            and upgraded to this point.
>>>>>            -Steve W
>>>>>            On 12/10/2011 5:46 PM, Aren Cambre wrote:
>>>>>                Thanks. Yup, I see it now. My mind was stuck in 3rd
>>>>>        generation
>>>>>                languages
>>>>>                where things stop when you get an exception.
>>>>>                The script's first gripe was that the *spatial_ref_sys*
>>>>>        table
>>>>>                already
>>>>>                exists. Shouldn't it automatically kill and reload that
>>>>>        table?
>>>>>                Is that a
>>>>>                bug?
>>>>>                Anyway, I deleted it and reran the script. Now I get a
>>>>>        bunch of
>>>>>                notices
>>>>>                about functions that don't exist. See attachment.
>>>>>                It appears it's mostly not finding overloads of
>>>>>        functions. E.g.,
>>>>>                it says
>>>>>                *populate_geometry_columns()* and
>>>>>                oid)* are
>>>>>                missing. I do have variants with different function
>>>>>        signatures:
>>>>>                *populate_geometry_columns( oid,boolean)* and
>>>>>                *populate_geometry_columns( boolean)*.
>>>>>                BTW, I'm trying to run this on my template PostGIS DB,
>>>>>        which I named
>>>>>                *spatial_db_template*.
>>>>>                Aren
>>>>>                On Sat, Dec 10, 2011 at 10:26 AM, Bborie Park
>>>>>        <bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>
>>>>>        <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>
>>>>>        <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>>>
>>>>> wrote:
>>>>>                    Oops!  My head is always in the raster world, so I
>>>>>        just ran
>>>>>                with the
>>>>>                    raster upgrade.  Sorry about that.
>>>>>                    If you're getting an error, you'll want to scroll up
>>>>>        past the
>>>>>                    transaction error message as the very first error
>>>>>        message
>>>>>                should be
>>>>>                    related to the actual statement that is failing.
>>>>>                    -bborie
>>>>>                    On Sat, Dec 10, 2011 at 6:47 AM, Aren Cambre
>>>>>        <aren at arencambre.com <mailto:aren at arencambre.com>
>>>>>        <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>
>>>>>        <mailto:aren at arencambre.com <mailto:aren at arencambre.com>>>**>
>>>>> wrote:
>>>>>         > Thanks. Yesterday I
>>>>>                    found postgis_upgrade_20_minor.sql in
>>>>>                /usr/share/postgresql/9.1/ contrib/postgis-2.0.
>>>>>         > When I ran that, I got tons of errors like this:
>>>>>                    psql:/usr/share/postgresql/9.
>>>>>        1/contrib/postgis-2.0/postgis_
>>>>>                upgrade_20_minor.sql:3235:
>>>>>         > ERROR:  current transaction is aborted, commands ignored
>>>>>                until end of
>>>>>         > transaction block
>>>>>         > I see you mentioned rtpostgis_upgrade_20_minor. sql. Isn't
>>>>> that
>>>>>                    just for
>>>>>         > raster functions? I searched my machine and cannot find it,
>>>>>                anyway.
>>>>>         > Aren
>>>>>         > On Fri, Dec 9, 2011 at 10:02 PM, Bborie Park
>>>>> wrote:
>>>>>         >> Aren,
>>>>>         >> Since you're tracking trunk, after you've done the
>>>>> configure,
>>>>>                    make and
>>>>>         >> make install, you'll want to run the upgrade script
>>>>>         >> rtpostgis_upgrade_20_minor.sql
>>>>>         >> Usually, the file is installed in the same place as
>>>>>                    rtpostgis.sql.  If
>>>>>         >> you can't find the upgrade file, you can find it in your
>>>>>                checkout's
>>>>>         >> directory at:
>>>>>         >> raster/rt_pg
>>>>>         >> -bborie
>>>>>         >> On Fri, Dec 9, 2011 at 7:53 PM, Aren Cambre
>>>>> wrote:
>>>>>         >> > Thanks. I got the latest SVN snapshot. I was able to
>>>>>                    configure, make,
>>>>>         >> > and
>>>>>         >> > make install. The problem is there seems to be missing
>>>>> steps
>>>>>                    between
>>>>>         >> > building the whole thing and getting changes into my
>>>>>                preexisting
>>>>>         >> > PostGIS-enabled database.
>>>>>         >> > Aren
>>>>>         >> > On Fri, Dec 9, 2011 at 9:47 PM, Bborie Park
>>>>> wrote:
>>>>>         >> >> If you used something like...
>>>>>         >> >> svn check out https://svn.osgeo.org/postgis/ trunk
>>>>>        <https://svn.osgeo.org/ postgis/trunk
>>>>>        <https://svn.osgeo.org/**postgis/trunk<https://svn.osgeo.org/postgis/trunk>
>>>>>         >> >> You can safely run...
>>>>>         >> >> svn update
>>>>>         >> >> If that works, I'd recommend doing...
>>>>>         >> >> svn cleanup
>>>>>         >> >> -bborie
>>>>>         >> >> On Fri, Dec 9, 2011 at 7:19 PM, Aren Cambre
>>>>>         >> >> wrote:
>>>>>         >> >> > I admit this is a dumb question, but here it is.
>>>>>         >> >> > I installed PostGIS on my Ubuntu 11.10 environment a
>>>>> few
>>>>>                    weeks ago
>>>>>         >> >> > using
>>>>>         >> >> > the
>>>>>         >> >> > excellent instructions
>>>>>         >> >> > at
>>>>>        http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>>>>                2010-data
>>>>>        <http://www.letseehere.com/ postgis-geocoder-using-tiger-
>>>>>        2010-data
>>>>>        <http://www.letseehere.com/**postgis-geocoder-using-tiger-**
>>>>> 2010-data<http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data>
>>>>>         >> >> > Since then, the geocode_intersection function was
>>>>> added,
>>>>>                    and I need
>>>>>         >> >> > it.
>>>>>         >> >> > I'm
>>>>>         >> >> > not clear what is the process of replacing the older
>>>>>                    snapshot of
>>>>>         >> >> > PostGIS
>>>>>         >> >> > with this newer one.
>>>>>         >> >> > I don't see an obvious install/uninstall routine. I
>>>>> tried
>>>>>                    the soft
>>>>>         >> >> > upgrade
>>>>>         >> >> > at
>>>>>        http://postgis.refractions. net/documentation/manual-svn/
>>>>>                postgis_installation.html# upgrading
>>>>>        <http://postgis.refractions. net/documentation/manual-svn/
>>>>>        <http://postgis.refractions.**net/documentation/manual-svn/**
>>>>> postgis_installation.html#**upgrading<http://postgis.refractions.net/documentation/manual-svn/postgis_installation.html#upgrading>
>>>>>         >> >> > but that didn't work. Do I need to do the hard upgrade
>>>>> each
>>>>>                    time I do
>>>>>         >> >> > a
>>>>>         >> >> > SVN
>>>>>         >> >> > update?
>>>>>         >> >> > Aren
>>>>>         >> >> > ______________________________ _________________
>>>>>         >> >> > postgis-users mailing list
>>>>>         >> >> > postgis-users at postgis. refractions.net
>>>>>        <http://refractions.net>
>>>>>        <mailto:postgis-users at postgis. refractions.net
>>>>>        <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>>>        <mailto:postgis-users at postgis <mailto:postgis-users at postgis>**.
>>>>>        refractions.net <http://refractions.net>
>>>>>                net/mailman/listinfo/postgis- users
>>>>>        <http://postgis.refractions. net/mailman/listinfo/postgis-
>>>>> users
>>>>>        <http://postgis.refractions.**net/mailman/listinfo/postgis-**
>>>>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>>>         >> >> Bborie Park
>>>>>         >> >> Programmer
>>>>>         >> >> Center for Vectorborne Diseases
>>>>>         >> >> UC Davis
>>>>>         >> >> 530-752-8380 <tel:530-752-8380> <tel:530-752-8380
>>>>>        <tel:530-752-8380>> <tel:530-752-8380 <tel:530-752-8380>
>>>>>        <tel:530-752-8380 <tel:530-752-8380>>>
>>>>>                users
>>>>> users
>>>>>                users
>>>>> users
>>>>>         >> Bborie Park
>>>>>         >> Programmer
>>>>>         >> UC Davis
>>>>>         >> postgis-users at postgis. refractions.net <
>>>>>                users
>>>>> users
>>>>>                users
>>>>> users
>>>>>                    Bborie Park
>>>>>                    Programmer
>>>>>                    UC Davis
>>>>>        http://postgis.refractions. net/mailman/listinfo/postgis- users
>>>>> users
>>>>> users
>>>>> users
>>>>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>>
>>>>>    <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111212/a28d55f3/attachment.html>
