[postgis-users] Raster pixel value
Andreas Forø Tollefsen
andreasft at gmail.com
Mon Dec 19 01:01:54 PST 2011
Hi Tom,
I tried both functions. The St_AreaWeightedSummaryStats() works great, but
it takes a lot of time to complete.
However, the ST_Clip() i cannot manage to get working. Seems like something
is broken. Any idea what can cause this error?
I installed the latest ST_SummaryStatsAgg() and ST_Clip() from
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql
The query:
SELECT foo2.gid,
(ss).count,
(ss).sum,
(ss).mean,
(ss).min,
(ss).max
FROM
(SELECT foo.gid, ST_SummaryStatsAgg(gv) ss
FROM (SELECT p.gid, ST_Clip(r.rast, p.cell) gv
FROM access r, priogrid_land p
WHERE ST_Intersects(r.rast, p.cell)
) foo
GROUP BY foo.gid
) foo2
Results in:
ERROR: function st_minpossiblevalue(text) does not exist
LINE 1: ...esce(nodata, ST_BandNodataValue(rast, bandstart), ST_MinPoss...
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
QUERY: SELECT coalesce(nodata, ST_BandNodataValue(rast, bandstart),
ST_MinPossibleValue(newpixtype))
CONTEXT: PL/pgSQL function "st_clip" line 31 at assignment
********** Error **********
SQL state: 42883
Hint: No function matches the given name and argument types. You might need
Context: PL/pgSQL function "st_clip" line 31 at assignment
2011/12/6 Tom van Tilburg <tom.van.tilburg at gmail.com>
> Andreas,
> I didn't have time to reproduce your problem yet. Did you have any succes
> by yourself on this issue?
> Could it have something to do with counting the non-data values as value?
> This is what I experience with a similar function (ST_Clip) that
> consequently gave me the value '0' instead of the nodata value. The result
> of that is that the mean was often lower than expected.
> Perhaps you could rewrite your previous example to something with
> auto-generated values in the script. That saves time in reproducing.
> Cheers,
> Tom
> On 25-11-2011 18:11, Andreas Forø Tollefsen wrote:
> Update:
> I think my suspicion is correct. If I do a ST_Summarystats().sum and
> divide this on 36 my MAX value will be 1.
> Hence, I think the number of values counted and the number of observations
> counted is not equal.
> New query:
> DROP TABLE IF EXISTS mountain_phil_cell;
> SELECT
> a.gid As gid,
> (ST_SummaryStats((ST_Union(ST_MapAlgebraExpr(ST_AsRaster(a.cell, b.rast,
> '32BF'), b.rast, 'rast2', '32BF','INTERSECTION','0','0',0))).rast,
> false)).sum / 36 As avgmnt
> INTO mountain_phil_cell
> FROM
> priogrid_land a LEFT JOIN
> mountain_phil b
> ON ST_Intersects(a.cell, b.rast)
> GROUP BY a.gid
> ORDER BY a.gid;
> 2011/11/25 Andreas Forø Tollefsen <andreasft at gmail.com>
>> A small note regarding this issue.
>> My problem is that I never get a mean value of 1 even if all pixels
>> inside the geometry is one.
>> Could this be because: 6x6 pixels goes into one polygon when visually
>> controlling. If each pixel has the value 1, then this will be calculated as
>> 36 / 36 = 1. However, if it calculates the sum to be 36 and divide by a
>> number higher than 36 pixels, then the result will always be below 1.
>> What i am thinking is that while it sums up the pixel values correctly,
>> it does not count only the 36 pixels, but also neighboring pixels.
>> Therefore: 1+1+1+1...n36 / Number of pixels higher than 36 will always lead
>> to a number lower than 1.
>> Anyone who knows the functions well could probably answer this.
>> Best regards,
>> Andreas
>>> Could this have to do with the tiling of the raster?
>>> I will try to run the same query with a untiled mountain raster to see
>>> if that changes anything.
>>> Btw. When loading a tiled postgis raster into qgis it shows up with
>>> many artifacts and no data areas. The same raster untiled does not show up
>>> the same way.
>>> Qgis bug?
>>> Andreas
>>>> Hi,
>>>> Thanks for all of the suggestions. I will do some more testing.
>>>> However, as for suggestion 1 i think the pixel size should be the same as
>>>> the original raster or am I wrong?
>>>> Both the mean_mnt_bin raster and the priogrid_land shapefile can be
>>>> downloaded as zip (2 mb) here:
>>>> http://gisintersect.com/mean_mnt_bin.zip
>>>> http://gisintersect.com/priogrid_land.zip
>>>> Any help on getting the correct values would be very much appreciated.
>>>> My query:
>>>> DROP TABLE IF EXISTS mountain_cell;
>>>> SELECT
>>>> a.gid As id,
>>>> b.rast, '32BF'), b.rast, 'rast2', '32BF','INTERSECTION','0','0',0))).rast,
>>>> false)).mean As avgmnt
>>>> INTO mountain_cell
>>>> FROM
>>>> mountain b
>>>> GROUP BY a.gid
>>>> ORDER BY a.gid;
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111219/84c47dd9/attachment.html>
