[postgis-users] How to look up state highways with geocoder?
Paragon Corporation
lr at pcorp.us
Tue Dec 20 12:56:56 PST 2011
Aren,
Can you ticket this one for us attaching the nice image you have.
http://trac.osgeo.org/postgis/
We agree it's most likely a bug and probably because of how they break out
the fields in highways and we're not using the fullname -- just the parts.
We had similar issues with the base geocoder which we fixed. So probably
just requires porting a bit of the same logic to fix.
Thanks,
Leo and Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Aren
Cambre
Sent: Monday, December 19, 2011 11:29 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] How to look up state highways with geocoder?
The plot thickens further. I used QGIS to view the tiger_data.tx_edges
table. I had it label everything using the fullname column. I found the
intersection:
So clearly, N Denton Tap Rd and State Hwy 121 intersect. However, both of
these queries produce no results (delta is highlighted):
SELECT * FROM geocode_intersection('State Hwy 121', 'N Denton Tap Rd', 'TX',
'Coppell');
'TX');
Certainly I'm hitting against a bug?
Aren
On Mon, Dec 19, 2011 at 9:19 PM, Aren Cambre <aren at arencambre.com> wrote:
Getting closer.
I checked the tiger_data.tx_featnames table's fullname column and am finding
many references to State Hwy 121, matched using like %121%.
To match Denton Tap Rd., I have to use like %Denton Tap% in my select. Lower
case (%denton tap%) produces no results--but not sure if that's relevant to
the geocode_intersection issue here.
OK, so I run this query:
SELECT * FROM geocode_intersection('State Hwy 121', 'Denton Tap', 'TX',
'Coppell');
...and get no results!
I also tried these:
* Denton Tap Rd
* N Denton Tap Rd
* S Denton Tap Rd
Not clear what's the deal here. One of these ought to match, especially
since there are two TX 121s meeting with Denton Tap.
I also tried omitting the city and still get nothing:
SELECT * FROM geocode_intersection('State Hwy 121', 'Denton Tap', 'TX');
Argh.
Aren
On Mon, Dec 19, 2011 at 8:54 PM, Aren Cambre <aren at arencambre.com> wrote:
Here's the query I'm using:
SELECT * FROM geocode_intersection('SH 121', 'Denton Tap', 'TX', 'Coppell');
Aren
On Mon, Dec 19, 2011 at 7:56 PM, Aren Cambre <aren at arencambre.com> wrote:
I am trying to find an intersection that includes a state highway. It's TX
121 and Denton Tap Rd. in Coppell, TX. This corresponds to here
<http://maps.google.com/maps?q=state+highway+121+%26+denton+tap,+coppell,+tx
&hl=en&ll=33.001068,-96.99373&spn=0.011067,0.015686&sll=32.969416,-96.993595
&sspn=0.011071,0.015686&vpsrc=6&t=w&hnear=Texas+121+Business+%26+Denton+Tap+
Rd,+Lewisville,+Denton,+Texas+75067&z=16> or here
&hl=en&ll=32.986562,-96.993257&spn=0.011069,0.015686&sll=32.969416,-96.99359
5&sspn=0.011071,0.015686&vpsrc=6&t=w&hnear=Texas+121+Business+%26+Denton+Tap
+Rd,+Lewisville,+Denton,+Texas+75067&z=16> (one is TX 121 main route and
the other is TX 121 Business).
I cannot figure out how to represent a state highway in the TIGER geocoder.
I've used all sorts of variants, like:
* SH 121
* state highway 121
* TX 121
* Texas state highway 121
etc.
How are state highways represented in the DB? How can I check road name
representations for myself in the future?
Aren
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111220/aa9da22d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111220/aa9da22d/attachment.png>
