[postgis-users] speeding up simple pt-in-poly lookups
Puneet Kishor
punk.kish at gmail.com
Tue Dec 20 17:49:38 PST 2011
On Dec 20, 2011, at 7:44 PM, Brian Stempin wrote:
> I've been out of the loop for a bit, but try this:
> SELECT Count(c_id)
> FROM c, continents n
> WHERE c.the_geom && n.the_geom AND
> ST_Intersects(c.the_geom, n.the_geom) AND
> n.continent = 'North America';
> The key line being:
If you see the EXPLAIN QUERY PLAN I posted (see below), ST_Intersects automatically does an && check. Nevertheless, I tried your specific suggestion above, and it took 201 seconds. No joy.
> Check out item 7.7:
> http://postgis.refractions.net/documentation/manual-1.5/reference.html
> The && uses the bounding boxes to check if they overlap. This is a very
> quick operation that might eliminate the need to further examine if two
> geoms are intersecting.
> HTH,
> Brian
> On Tue, Dec 20, 2011 at 8:28 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>> On Dec 20, 2011, at 7:21 PM, Paul Ramsey wrote:
>>> Chop up the continents into smaller pieces.
>> hmmm... I am not sure I understand the above. And then what? UNION each
>> smaller piece query?
>>> On Tue, Dec 20, 2011 at 4:35 PM, Puneet Kishor <punk.kish at gmail.com>
>> wrote:
>>>> This is probably a really basic question... my ST_Within or
>> ST_Intersects selecting points in a continent are way too slow (both take
>> upward of 200 secs).
>>>> SELECT Count(c_id)
>>>> WHERE ST_Intersects(c.the_geom, n.the_geom) AND
>>>> Both tables have gist indexes on the geometries. The above query has
>> the following plan
>>>> "Aggregate (cost=9.66..9.67 rows=1 width=4)"
>>>> " -> Nested Loop (cost=0.00..9.66 rows=1 width=4)"
>>>> " Join Filter: _st_intersects(c.the_geom, n.the_geom)"
>>>> " -> Seq Scan on continents n (cost=0.00..1.10 rows=1
>> width=32)"
>>>> " Filter: ((continent)::text = 'North America'::text)"
>>>> " -> Index Scan using pbdb__collections_the_geom on collections
>> c (cost=0.00..8.30 rows=1 width=104)"
>>>> " Index Cond: (c.the_geom && n.the_geom)"
>>>> The table c has approx 120K rows, and the continents table has 8
>> rows.Suggestions on how I can improve this? Yes, the computer is otherwise
>> very swift and modern.
>>>> Puneet Kishor
