[postgis-users] speeding up simple pt-in-poly lookups
pcreso at pcreso.com
Tue Dec 20 22:01:38 PST 2011
Try this:
Create a table with chopped up polygons derived from your continents table.
Say you have continents (continent_id, name, the_geom)
then you have continents_chopped(chop_id, continent_id, continent_name, the_geom)
Spatial index on continents_chopped.polygon
SELECT Count(distinct continent_id)
FROM c, continents_chopped n
WHERE ST_Intersects(c.the_geom, n.the_geom) AND
n.continent = 'North America';
the BB index will very quickly identify a few chopped polygons which contain the point, then the much slower test against all the vertices in the continent polygons is carried out against a few chopped polygons with vastly fewer vertices, making for a much faster operation.
This, from an email I sent a colleague a few weeks ago may be helpful:
As far as an easy way to generate a grid of specified size cells over a specified area, see:
http://trac.osgeo.org/postgis/wiki/UsersWikiCreateFishnet
Thus allowing arbitrary slicing/binning of polygons via a simple overlay operation - ST_Intersection()
This can be wrapped up in a shell script which generates the grid, as below:
#! /bin/bash
# script to generate an arbitrary grid
# test only
# B Wood 12/11/2011
DB=test_grid
# create db
dropdb $DB
createdb $DB
psql -d $DB -qf /usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql
psql -d $DB -qf /usr/share/postgresql/9.1/contrib/postgis-1.5/spatial_ref_sys.sql
# create function
psql -d $DB -c "CREATE OR REPLACE FUNCTION ST_CreateGrid(
nrow integer, ncol integer,
xsize float8, ysize float8,
x0 float8 DEFAULT 0, y0 float8 DEFAULT 0,
srid integer DEFAULT 4326)
RETURNS SETOF geometry AS
SELECT ST_Translate(cell, j * \$3 + \$5, i * \$4 + \$6)
FROM generate_series(0, \$1 - 1) AS i,
generate_series(0, \$2 - 1) AS j,
SELECT setsrid(('POLYGON((0 0, 0 '||\$4||', '||\$3||' '||\$4||', '||\$3||' 0,0 0))')::geometry, \$7) AS cell
) AS foo;
\$\$ LANGUAGE sql IMMUTABLE STRICT;"
# create table
psql -d $DB -c "create table test_grid
( id serial primary key);"
psql -d $DB -c "select
addgeometrycolumn('','test_grid','geom',4326,'POLYGON',2);"
# create lat/long grid
# set extent
W=150
E=190
S=-55
N=-30
SRID=4326
# set cell size in degrees
SIZE=0.05
# get cell counts for extent
NX=`echo "($E - $W) / $SIZE" | bc`
NY=`echo "($N - $S) / $SIZE" | bc | tr -d "-"`
# create grid
psql -d $DB -c "delete from test_grid;"
psql -d $DB -c "insert into test_grid (geom)
select ST_CreateGrid($NY,$NX,$SIZE,$SIZE,$W.0,$S.0,$SRID);"
--- On Wed, 12/21/11, Puneet Kishor <punk.kish at gmail.com> wrote:
Subject: Re: [postgis-users] speeding up simple pt-in-poly lookups
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Wednesday, December 21, 2011, 2:28 PM
On Dec 20, 2011, at 7:21 PM, Paul Ramsey wrote:
> Chop up the continents into smaller pieces.
hmmm... I am not sure I understand the above. And then what? UNION each smaller piece query?
> On Tue, Dec 20, 2011 at 4:35 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>> This is probably a really basic question... my ST_Within or ST_Intersects selecting points in a continent are way too slow (both take upward of 200 secs).
>> SELECT Count(c_id)
>> FROM c, continents n
>> Both tables have gist indexes on the geometries. The above query has the following plan
>> "Aggregate (cost=9.66..9.67 rows=1 width=4)"
>> " -> Nested Loop (cost=0.00..9.66 rows=1 width=4)"
>> " Join Filter: _st_intersects(c.the_geom, n.the_geom)"
>> " -> Seq Scan on continents n (cost=0.00..1.10 rows=1 width=32)"
>> " Filter: ((continent)::text = 'North America'::text)"
>> " -> Index Scan using pbdb__collections_the_geom on collections c (cost=0.00..8.30 rows=1 width=104)"
>> " Index Cond: (c.the_geom && n.the_geom)"
>> The table c has approx 120K rows, and the continents table has 8 rows.Suggestions on how I can improve this? Yes, the computer is otherwise very swift and modern.
>> Puneet Kishor
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111220/5330c9b8/attachment.html>
