[postgis-users] FW: [postgis-devel] PostGIS 2.0.0SVN: TIGER Geocoder and TIGER'sown Primary Keys and the use of tableA.statefp =tableB.statefp: I think its' a kludge
Steve Walker
walker at mfgis.com
Wed Dec 21 11:48:36 PST 2011
OK, I'll just see what I can achieve on my own and report back if I can
make any progress. I don't believe that topology is any way a
requirement, but do see where building some of the lookup tables a
priori would eliminate point-in-poly queries on the fly.
Thanks again,
-Steve
On Wed, 2011-12-21 at 14:37 -0500, Paragon Corporation wrote:
> Just realized I sent this to the wrong list.
> -----Original Message-----
> From: Paragon Corporation [mailto:lr at pcorp.us]
> Sent: Wednesday, December 21, 2011 6:27 AM
> To: 'PostGIS Development Discussion'
> Subject: RE: [postgis-devel] PostGIS 2.0.0SVN: TIGER Geocoder and TIGER'sown
> kludge
> > Yet my biggest personal
> > challenge is reading through the sql code and the chained clauses,
> > in
> > for example 'geocode.sql'. A couple things that just made
> > it tough for
> > me to understand - beyond my limited ability to chain together all the
> > clauses - is some of the uses of aliases in the sql code.
> > At one point
> > 'f' is an alias for 'featnames' at another point 'f' is an alias for
> > 'faces.' I'm trying to re-write stuff by dropping the
> > aliases in
> > favor of explicit table.attribute syntax so I can more
> > > explicitly see
> > the actual tables and attributes with which I'm working.
> Steve,
> I have mixed feelings about this. I wasn't the one that wrote the bulk of
> the sql.
> Steve Frost and his friend (who I can't quite remember his name) did that
> and I didn't have any problems reading there code. They did a great job in
> fact.
> The main issue I have with using the correct name is 2
> 1) Practicality - you can't because some pieces do require joining by the
> same table more than once so at least one is not going to have the same name
> and the other is not. Sure you could alias it to be suffixed with faceA ,
> faceB etc. So that's minor
> 2) It's a pain to type and the extended length makes it harder for me to
> read as I have more lines to scan to gain clarity.
> That said I'm not totally against the idea if people feel it would make it
> easier for them to understand and contribute.
> On the pro side, I think I did get a bit lazy and when I was folding queries
> or expanding them it was faster to just move the logic up and change the
> alias to where it was before. Thus getting into your frustration with the
> same alias used to mean different things.
> That should probably be changed.
> > I do think I have a 100% complete and properly normalized TIGER 2010
> > database to work against if that helps.
> It would be useful to see if that helps with the speed of some things. I
> think the faces it would. edges I doubt it.
> As far as removing statefp -- I don't see that working without just dumping
> all the data into the same tables. Without that your vision of a perfectly
> normalized TIGER is not attainable as you'd still have dupes in the state
> tables.
> Keep in mind we chose to break data out by state not just for speed reasons,
> but for maintainability.
> a) We work with a lot of of users and most of them need only one state full
> of data.
> Its easier to load one set of state tables from one database to another than
> to try to copy the whole thing for obvious reasons.
> That is actually the primary reason we broke the data up this way.
> b) The second is for speed, since for at least lower systems with lower
> memory the partitioned approach seemed to be better speedwise.
> For a system with lots of memory may not make too much of a difference.
> I can not stress enough that we care more about ease of use and speed than
> how normalized our data is. Normalization is important when you are
> managing / modifying TIGER data, but not when you are using it for
> geocoding. With that said, I would suggest you look at the PostGIS Topology
> model.
> If ever we were to build a geocoder on a normalized system (which would have
> the side benefity of being useful for local gov TIGER management), it would
> be based on PostGIS Topology.
> Thanks,
> Regina
> http://www.postgis.us
Steve Walker
Middle Fork Geographic Information Services
(360)671-2505
