[postgis-users] raster map algebra question(s)
Paragon Corporation
lr at pcorp.us
Thu Dec 22 11:44:27 PST 2011
Steve,
Depends how your data is setup -- I'm assuming you are looking for a moving
average?
If for example you have a raster record for each date in the same table,
with a field denoting the date, then the best bet is probably use ST_Union
with the optional MEAN expression.
I haven't stress tested that yet.
So say you have a table
Rast, temp_date
Then you can do a
SELECT ST_Union(rast, 'MEAN' ) OVER (ROWS BETWEEN 1 PRECEDING AND CURRENT
ROW ORDER BY temp_date) As newrast, temp_date
FROM temperatures;
Haven't tried using with window aggregates , but the above should work.
Also note the ROWS with number ranges was introduced in PostgreSQL 9.0 so
that particular syntax won't work with 8.4.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Crawford
Sent: Thursday, December 22, 2011 2:23 PM
To: PostGIS Users Discussion
Subject: [postgis-users] raster map algebra question(s)
Thanks to all who helped me on my previous raster output questions; I now
have a better handle on what I can (and can't) do.
How can I do map algebra across raster tables? I have a db of raster tables
(all the same extend) with weather variables by date. I have a number of
ways i want to use these data, but in the initial case I would like to, as
an example, create a new raster table where the data value at each cell is
the average of the previous day's values. Any thoughts?
Thanks,
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
