[postgis-users] Installing a fully functional PostGIS 2.0 on Ubuntu Linux GEOS/GDAL issues
THX1138
ap.joseph at live.com
Sun Dec 25 10:53:14 PST 2011
Thanks, for your help on this I would have never figured this out as the
config shows my 3.3.1 GEOS, so I figured it was using the right version when
making.
The problem is that a dependency of libgdal1-dev (the 1.8 version) is
libgeos-dev which installs and older version of the geos, so if I delete
them, I assume gdal will give me an error when making postgis.
Perhaps I can uninstall gdal and build gdal from source using the 3.3.1
geos, although I bet this would create another mess.
Can you shed some more light on the editing the makefile option?
Thanks again!
Andrew
Sandro Santilli wrote:
> On Sat, Dec 24, 2011 at 09:12:28PM -0800, THX1138 wrote:
>> -------------- Dependencies --------------
>> GEOS config: /usr/local/bin/geos-config
>> GEOS version: 3.3.1
>> -L/usr/lib
>> -lgdal1.8.0 -L/usr/local/lib -lgeos_c -lm -o raster2pgsql
>> /home/zonabili/postgis-2.0.0SVN/liblwgeom/lwgeom_geos.c:319: undefined
>> reference
>> to `GEOSGeom_createEmptyPolygon'
> The problem is with -L/usr/lib coming before -L/usr/local/lib which
> makes the old geos be found before the new one.
> Simplest thing would be dropping the old geos as a whole.
> Harder, opening the relevant Makefile and removing the -L/usr/lib
> --strk;
> ,------o-.
> | __/ | Thank you for PostGIS-2.0 Topology !
> | / 2.0 | http://www.pledgebank.com/postgistopology
> `-o------'
> postgis-users mailing list
View this message in context: http://old.nabble.com/Installing-a-fully-functional-PostGIS-2.0-on-Ubuntu-Linux-GEOS-GDAL-issues-tp33035173p33036358.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
