[postgis-users] Geographic Coordinates
pcreso at pcreso.com
Sat Dec 31 11:14:52 PST 2011
Hi Daniel,
The GUI is only available for Windows, which I haven't used much for some years now. So I can't help with that aspect. I would assume the GUI has some way for you to enter the same parameters.
As often as not, I find a GUI is an intermediary between me & the application I want to run. If I know the application well, I often don't want an intermediary, I want to directly control the application myself :-) But there are applications where a GUI is facilitative & useful rather than just a limited menu.
You can run the commands in the command prompt/DOS shell/Windows Terminal or whatever it is called these days.
Cheers,
Brent
--- On Sun, 1/1/12, Daniel Montenegro <dmontenegro84 at gmail.com> wrote:
From: Daniel Montenegro <dmontenegro84 at gmail.com>
Subject: Re: [postgis-users] Geographic Coordinates
To: pcreso at pcreso.com
Date: Sunday, January 1, 2012, 2:54 AM
Thanks again Brent! Could you explain it a little bit more detailed? I'm using the shp2pgsql-gui (exe) to import shapefiles and there's no need to wright any command... So I don't know where I should wright this specific comand line. Maybe in the PSQL console (pgadmin)?
Daniel
2011/12/31 <pcreso at pcreso.com>
pgsql2shp -s 4326 -I <shapefile> <mytable> | psql -d <mydb>
where
<shapefile> is the name of your shapefile, eg: myfile.shp
<mytable> is the name of the POstgis table to create & populate
<mydb> is the name of od the Postgis database (Postgres with Postgis installed)
"-s 4326" tells pgsql to create a table for a shapefile with lat/long geometries, as in
http://www.spatialreference.org/ref/epsg/4326/
HTH,
Brent Wood
Subject: [postgis-users] Geographic
Coordinates
To: "postgis-users" <postgis-users at postgis.refractions.net>
Date: Saturday, December 31, 2011, 4:57 PM
Hi there! How can I import a shape file with geographic coordinates to PostGIS via shp2pgsql? Thanks Daniel
-----Inline Attachment Follows-----
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111231/1a3385dd/attachment.html>
